assastri
Spam detection software, running on the system "mgmt-01.angryhosting.com", has
identified this incoming email as possible spam. The original message has been attached to this so you can view it (if it isn't spam) or label similar future email. If you have any questions, see The administrator of that system for details. Content preview: Fertility boost to your benefit with Spermamax. Lasix helps with swelling development treatment. Fertility boost to your benefit with Spermamax. Lasix helps with swelling development treatment. [...] Content analysis details: (28.1 points, 5.0 required) pts rule name description ---- ---------------------- -------------------------------------------------- 1.5 HELO_DYNAMIC_DHCP Relay HELO'd using suspicious hostname (DHCP) 2.9 HELO_DYNAMIC_IPADDR Relay HELO'd using suspicious hostname (IP addr 1) 0.5 RCVD_IN_PBL RBL: Received via a relay in Spamhaus PBL [190.1.223.66 listed in zen.spamhaus.org] 1.6 RCVD_IN_SORBS_DUL RBL: SORBS: sent directly from dynamic IP address [190.1.223.66 listed in dnsbl.sorbs.net] 1.2 SPF_NEUTRAL SPF: sender does not match SPF record (neutral) 1.8 DATE_IN_PAST_12_24 Date: is 12 to 24 hours before Received: date 0.0 HTML_MESSAGE BODY: HTML included in message 1.5 RAZOR2_CF_RANGE_E8_51_100 Razor2 gives engine 8 confidence level above 50% [cf: 100] 0.5 RAZOR2_CHECK Listed in Razor2 (http://razor.sf.net/) 0.5 RAZOR2_CF_RANGE_51_100 Razor2 gives confidence level above 50% [cf: 100] 2.0 URIBL_BLACK Contains an URL listed in the URIBL blacklist [URIs: harmonymost.com] 1.6 URIBL_AB_SURBL Contains an URL listed in the AB SURBL blocklist [URIs: harmonymost.com] 2.1 URIBL_WS_SURBL Contains an URL listed in the WS SURBL blocklist [URIs: harmonymost.com] 2.9 URIBL_JP_SURBL Contains an URL listed in the JP SURBL blocklist [URIs: harmonymost.com] 2.1 URIBL_OB_SURBL Contains an URL listed in the OB SURBL blocklist [URIs: harmonymost.com] 2.5 URIBL_SC_SURBL Contains an URL listed in the SC SURBL blocklist [URIs: harmonymost.com] 0.1 RDNS_NONE Delivered to trusted network by a host with no rDNS 2.8 DOS_OE_TO_MX Delivered direct to MX with OE headers The original message was not completely plain text, and may be unsafe to open with some email clients; in particular, it may contain a virus, or confirm that your address can receive spam. If you wish to view it, it may be safer to save it to a file and open it with an editor. |
