RE: Need some clutch help 95 VFR
I am refering to when the I am on the bike and not on the center stand, I
can feel the clutch engaging and disengaging a bit but not enough to stop the rear wheel from rotating. As I said I replaced my clutch and springs with EBC kevlar plates, I thought that kevlar and synth oil might have a problem working together or something, I triple checked everything. I was wondering if there is some adjustment that I need to do? Maybe I need to go back and check the springs and check the tension on them, I hate to do that because I am pretty sure that I am going to ruin my new gasket that I put on the side cover. Any other ideas? Darrin >From: "Dutch Viffer" >To: "'Darrin Blackman'" >Subject: RE: Need some clutch help 95 VFR >Date: Sat, 25 Feb 2006 23:40:04 +0100 > > >-----BEGIN PGP SIGNED MESSAGE----- >Hash: SHA1 > > > meaning when I go from neutral to first with the clutch > > pulled in the wheel rotates. I know that I need to seat the > >There is always some drag in the clutch that makes the wheel turn if >it's off the ground. Just as long as it doesn't pull when you are >standing still, you're fine. > >Gijs > >afterburn >http://www.vfr750.com >http://www.crashdot.com >ICQ: 187800 >FJR1300A > _____ > >"The saddest aspect of life right now is that science gathers >knowledge faster than society gathers wisdom." > - Isaac Asimov > > >-----BEGIN PGP SIGNATURE----- >Version: PGP 8.0.3 > >iQA/AwUBRADcxAmn0BNopOB7EQKQ+gCg7FInbKxU5t+AsplgJjl7kAi5Pb8AoNZF >aU4/JVuleQP1Cjw3bGVPYPAG >=F6Jv >-----END PGP SIGNATURE----- > _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: Need some clutch help 95 VFR
Did you let the new clutch plates soak in oil prior to installing them?
Travis '95 RC36 '01 SV650S '04 DR650 '85 VF500F '03 SV1000 race bike FOR SALE _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Do you mean the clutch is fully disengaged by pulling in the lever just the
smallest amount? -Chris ________________________________ From: vfr-bounces@xxxxxx on behalf of Darrin Blackman Sent: Sat 2/25/2006 3:54 PM To: vfr@xxxxxx Subject: RE: Need some clutch help 95 VFR Ok I just went around the block again and here is what I can tell you, the clutch does not fully engage, and is fully disengaged just by letting out on the lever just the smallest amount. So I am wondering if there is some adjustment that I am not familar with. I know that there is an adjustment on the lever but I am not sure that will do anything other than move the position of the lever in and out. Any help??? Darrin >From: "Darrin Blackman" >To: vfr@xxxxxx >Subject: RE: Need some clutch help 95 VFR >Date: Sat, 25 Feb 2006 23:37:01 +0000 > >I am refering to when the I am on the bike and not on the center stand, I >can feel the clutch engaging and disengaging a bit but not enough to stop >the rear wheel from rotating. As I said I replaced my clutch and springs >with EBC kevlar plates, I thought that kevlar and synth oil might have a >problem working together or something, I triple checked everything. I was >wondering if there is some adjustment that I need to do? Maybe I need to >go >back and check the springs and check the tension on them, I hate to do that >because I am pretty sure that I am going to ruin my new gasket that I put >on >the side cover. > >Any other ideas? > >Darrin > > > >From: "Dutch Viffer" > >To: "'Darrin Blackman'" > >Subject: RE: Need some clutch help 95 VFR > >Date: Sat, 25 Feb 2006 23:40:04 +0100 > > > > > >-----BEGIN PGP SIGNED MESSAGE----- > >Hash: SHA1 > > > > > meaning when I go from neutral to first with the clutch > > > pulled in the wheel rotates. I know that I need to seat the > > > >There is always some drag in the clutch that makes the wheel turn if > >it's off the ground. Just as long as it doesn't pull when you are > >standing still, you're fine. > > > >Gijs > > > >afterburn > >http://www.vfr750.com > >http://www.crashdot.com > >ICQ: 187800 > >FJR1300A > > _____ > > > >"The saddest aspect of life right now is that science gathers > >knowledge faster than society gathers wisdom." > > - Isaac Asimov > > > > > >-----BEGIN PGP SIGNATURE----- > >Version: PGP 8.0.3 > > > >iQA/AwUBRADcxAmn0BNopOB7EQKQ+gCg7FInbKxU5t+AsplgJjl7kAi5Pb8AoNZF > >aU4/JVuleQP1Cjw3bGVPYPAG > >=F6Jv > >-----END PGP SIGNATURE----- > > > > >_______________________________________________ >Vfr mailing list >Vfr@xxxxxx >For subscription and delivery options: >https://lists.cs.wisc.edu/mailman/listinfo/vfr _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Ok, please forgive me I am speaking backwards. I cannot fully disengage the
clutch by pulling in the lever and when I start to release the lever just a tiny bit the clutch is fully engaged, this is all with the bike on the ground. I think.....THINK....that I tightened the spring bolts too much. Does that sound like that might be the cause of this??? Once again, my brain is fried sorry about speaking backward clutch speak. Darrin >From: "Chris Burgess" >To: "Darrin Blackman" >Subject: RE: Need some clutch help 95 VFR >Date: Sat, 25 Feb 2006 16:50:53 -0800 > >Do you mean the clutch is fully disengaged by pulling in the lever just the >smallest amount? > >-Chris > >________________________________ > >From: vfr-bounces@xxxxxx on behalf of Darrin Blackman >Sent: Sat 2/25/2006 3:54 PM >To: vfr@xxxxxx >Subject: RE: Need some clutch help 95 VFR > > > >Ok I just went around the block again and here is what I can tell you, the >clutch does not fully engage, and is fully disengaged just by letting out >on >the lever just the smallest amount. So I am wondering if there is some >adjustment that I am not familar with. I know that there is an adjustment >on the lever but I am not sure that will do anything other than move the >position of the lever in and out. Any help??? > >Darrin > > > >From: "Darrin Blackman" > >To: vfr@xxxxxx > >Subject: RE: Need some clutch help 95 VFR > >Date: Sat, 25 Feb 2006 23:37:01 +0000 > > > >I am refering to when the I am on the bike and not on the center stand, I > >can feel the clutch engaging and disengaging a bit but not enough to stop > >the rear wheel from rotating. As I said I replaced my clutch and springs > >with EBC kevlar plates, I thought that kevlar and synth oil might have a > >problem working together or something, I triple checked everything. I >was > >wondering if there is some adjustment that I need to do? Maybe I need to > >go > >back and check the springs and check the tension on them, I hate to do >that > >because I am pretty sure that I am going to ruin my new gasket that I put > >on > >the side cover. > > > >Any other ideas? > > > >Darrin > > > > > > >From: "Dutch Viffer" > > >To: "'Darrin Blackman'" > > >Subject: RE: Need some clutch help 95 VFR > > >Date: Sat, 25 Feb 2006 23:40:04 +0100 > > > > > > > > >-----BEGIN PGP SIGNED MESSAGE----- > > >Hash: SHA1 > > > > > > > meaning when I go from neutral to first with the clutch > > > > pulled in the wheel rotates. I know that I need to seat the > > > > > >There is always some drag in the clutch that makes the wheel turn if > > >it's off the ground. Just as long as it doesn't pull when you are > > >standing still, you're fine. > > > > > >Gijs > > > > > >afterburn > > >http://www.vfr750.com > > >http://www.crashdot.com > > >ICQ: 187800 > > >FJR1300A > > > _____ > > > > > >"The saddest aspect of life right now is that science gathers > > >knowledge faster than society gathers wisdom." > > > - Isaac Asimov > > > > > > > > >-----BEGIN PGP SIGNATURE----- > > >Version: PGP 8.0.3 > > > > > >iQA/AwUBRADcxAmn0BNopOB7EQKQ+gCg7FInbKxU5t+AsplgJjl7kAi5Pb8AoNZF > > >aU4/JVuleQP1Cjw3bGVPYPAG > > >=F6Jv > > >-----END PGP SIGNATURE----- > > > > > > > > >_______________________________________________ > >Vfr mailing list > >Vfr@xxxxxx > >For subscription and delivery options: > >https://lists.cs.wisc.edu/mailman/listinfo/vfr > > >_______________________________________________ >Vfr mailing list >Vfr@xxxxxx >For subscription and delivery options: >https://lists.cs.wisc.edu/mailman/listinfo/vfr > > _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Sounds like what happens when the single ball that fits on the end of the
clutch pushrod (inside the tranny shaft) falls out when the clutch is being serviced. Not sure if your bike is supposed to have one of these little bearings, but if so...and if it is missing, you might get symptoms similar to what you describe. ??? I also think that you are saying disengage when you mean engage and you are saying engage when you mean disengage. The clutch is engaged when the lever is out and you are riding, it is disengaged when the lever is pulled in to the grip. I think you mean that it will not disengage the tranny from the engine .... and it is fully engaged as soon as you start releasing the lever. Again, if I understand you, this may be caused by a missing ball in the clutch pushrod assembly. It could also be due to air in the hydraulic system. Pumping the lever may not get it all, you need a vacuum or pressure bleeder to get all the air out. One other thing...any possibility that you installed one too many plates or installed the plates out of sequence? Stranger things have happened... Hope that helps, John Harrison Birmingham ----- Original Message ----- From: "Darrin Blackman" To: Sent: Saturday, February 25, 2006 5:54 PM Subject: RE: Need some clutch help 95 VFR > Ok I just went around the block again and here is what I can tell you, the > clutch does not fully engage, and is fully disengaged just by letting out > on > the lever just the smallest amount. So I am wondering if there is some > adjustment that I am not familar with. I know that there is an adjustment > on the lever but I am not sure that will do anything other than move the > position of the lever in and out. Any help??? > > Darrin > _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Hi Darrin
I think tightening the spring bolts too much could be the problem. But I also recall something about the plates have to be installed with the correct side facing the same direction, did you do that? Cheers, Bob Saturday, February 25, 2006, 7:36:40 PM, you wrote: > Ok, please forgive me I am speaking backwards. I cannot fully disengage the > clutch by pulling in the lever and when I start to release the lever just a > tiny bit the clutch is fully engaged, this is all with the bike on the > ground. I think.....THINK....that I tightened the spring bolts too much. > Does that sound like that might be the cause of this??? Once again, my > brain is fried sorry about speaking backward clutch speak. > Darrin >>From: "Chris Burgess" >>To: "Darrin Blackman" >>Subject: RE: Need some clutch help 95 VFR >>Date: Sat, 25 Feb 2006 16:50:53 -0800 >> >>Do you mean the clutch is fully disengaged by pulling in the lever just the >>smallest amount? >> >>-Chris >> >>________________________________ >> >>From: vfr-bounces@xxxxxx on behalf of Darrin Blackman >>Sent: Sat 2/25/2006 3:54 PM >>To: vfr@xxxxxx >>Subject: RE: Need some clutch help 95 VFR >> >> >> >>Ok I just went around the block again and here is what I can tell you, the >>clutch does not fully engage, and is fully disengaged just by letting out >>on >>the lever just the smallest amount. So I am wondering if there is some >>adjustment that I am not familar with. I know that there is an adjustment >>on the lever but I am not sure that will do anything other than move the >>position of the lever in and out. Any help??? >> >>Darrin >> >> >> >From: "Darrin Blackman" >> >To: vfr@xxxxxx >> >Subject: RE: Need some clutch help 95 VFR >> >Date: Sat, 25 Feb 2006 23:37:01 +0000 >> > >> >I am refering to when the I am on the bike and not on the center stand, I >> >can feel the clutch engaging and disengaging a bit but not enough to stop >> >the rear wheel from rotating. As I said I replaced my clutch and springs >> >with EBC kevlar plates, I thought that kevlar and synth oil might have a >> >problem working together or something, I triple checked everything. I >>was >> >wondering if there is some adjustment that I need to do? Maybe I need to >> >go >> >back and check the springs and check the tension on them, I hate to do >>that >> >because I am pretty sure that I am going to ruin my new gasket that I put >> >on >> >the side cover. >> > >> >Any other ideas? >> > >> >Darrin >> > >> > >> > >From: "Dutch Viffer" >> > >To: "'Darrin Blackman'" >> > >Subject: RE: Need some clutch help 95 VFR >> > >Date: Sat, 25 Feb 2006 23:40:04 +0100 >> > > >> > > >> > >-----BEGIN PGP SIGNED MESSAGE----- >> > >Hash: SHA1 >> > > >> > > > meaning when I go from neutral to first with the clutch >> > > > pulled in the wheel rotates. I know that I need to seat the >> > > >> > >There is always some drag in the clutch that makes the wheel turn if >> > >it's off the ground. Just as long as it doesn't pull when you are >> > >standing still, you're fine. >> > > >> > >Gijs >> > > >> > >afterburn >> > >http://www.vfr750.com >> > >http://www.crashdot.com >> > >ICQ: 187800 >> > >FJR1300A >> > > _____ >> > > >> > >"The saddest aspect of life right now is that science gathers >> > >knowledge faster than society gathers wisdom." >> > > - Isaac Asimov >> > > >> > > >> > >-----BEGIN PGP SIGNATURE----- >> > >Version: PGP 8.0.3 >> > > >> > >iQA/AwUBRADcxAmn0BNopOB7EQKQ+gCg7FInbKxU5t+AsplgJjl7kAi5Pb8AoNZF >> > >aU4/JVuleQP1Cjw3bGVPYPAG >> > >=F6Jv >> > >-----END PGP SIGNATURE----- >> > > >> > >> > >> >_______________________________________________ >> >Vfr mailing list >> >Vfr@xxxxxx >> >For subscription and delivery options: >> >https://lists.cs.wisc.edu/mailman/listinfo/vfr >> >> >>_______________________________________________ >>Vfr mailing list >>Vfr@xxxxxx >>For subscription and delivery options: >>https://lists.cs.wisc.edu/mailman/listinfo/vfr >> >> > _______________________________________________ > Vfr mailing list > Vfr@xxxxxx > For subscription and delivery options: > https://lists.cs.wisc.edu/mailman/listinfo/vfr _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Hey guys,
When I went for the Barnett plates and springs, I also went for new metal plates. Clutch installation went fine. It was slipping bad before the change (60,000 miles) and I figured I'd change everything. the Barnett clutch slipped lightly for the next 100 miles, and it's been fine ever since. I don't actually notice much difference in the lever. The "clutch engagement" range is certainly long enough. Could the new metal plates help with proper clutch operation ???!? Also, my VFR is a '98, so clutch may not be same as a '95 .... Olivier '98VFR800 Yellow > ------------------------------ > > Message: 5 > Date: Sat, 25 Feb 2006 22:30:07 -0600 > From: Bob Chappuis > Subject: Re: Need some clutch help 95 VFR > To: "Darrin Blackman" > Cc: vfr@xxxxxx > Message-ID: <1306370936.20060225223007@xxxxxx> > Content-Type: text/plain; charset=us-ascii > > Hi Darrin > I think tightening the spring bolts too much could be the problem. But > I also recall something about the plates have to be installed with the > correct > side facing the same direction, did you do that? > > Cheers, > Bob > Saturday, February 25, 2006, 7:36:40 PM, you wrote: >> Ok, please forgive me I am speaking backwards. I cannot fully disengage >> the >> clutch by pulling in the lever and when I start to release the lever just >> a >> tiny bit the clutch is fully engaged, this is all with the bike on the >> ground. I think.....THINK....that I tightened the spring bolts too much. >> Does that sound like that might be the cause of this??? Once again, my >> brain is fried sorry about speaking backward clutch speak. > >> Darrin > > >>>From: "Chris Burgess" >>>To: "Darrin Blackman" >>>Subject: RE: Need some clutch help 95 VFR >>>Date: Sat, 25 Feb 2006 16:50:53 -0800 >>> >>>Do you mean the clutch is fully disengaged by pulling in the lever just >>>the >>>smallest amount? >>> >>>-Chris >>> >>>________________________________ _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
On 2/28/06, Olivier
> > Hey guys, > > When I went for the Barnett plates and springs, I also went for new metal > plates. Clutch installation went fine. It was slipping bad before the > change > (60,000 miles) and I figured I'd change everything. My 98 is about to turn over 90,000 miles. Original clutch. Should I be planning on a new clutch sometime soon? John in Calif _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
I missed the start of this thread, but would suggest that the hydraulic
side of things is worth checking out given the symptoms. Start by pulling the slave cylinder off and ensuring that it is retracting fully into the bore; if it's not, the clutch will slip. Pump it out carefully with the lever and see if it sticks before getting to full travel (watch you don't push it right out of the bore); if it sticks, then it's not completely disengaging the clutch, and you'll get the symptoms described (very early take-up, bike trying to move when stationary in gear with clutch in). Slave cylinder rebuild kits are available from Honda dealers, but just pulling the piston, cleaning the bore and reassembling with fresh fluid top to bottom should be enough to get you by (it's not as critical as brakes, which do need proper overhauling). Also ensure that the actuating rod that goes through the motor from slave cyl to clutch is moving freely; clean and re-grease is recommended. A VFRd member recommends a cable-clutch conversion for the 4th Gen, which I am quite intrigued by... Regards Murray Sydney 1994 VFR750 project with Barnett clutch and fixed sticky slave cylinder _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
John Alexander wrote:
> > > On 2/28/06, *Olivier* > > Hey guys, > > When I went for the Barnett plates and springs, I also went for > new metal > plates. Clutch installation went fine. It was slipping bad before > the change > (60,000 miles) and I figured I'd change everything. > > > > My 98 is about to turn over 90,000 miles. > Original clutch. > Should I be planning on a new clutch sometime soon? > > John in Calif > > Probably. When I did mine at around 78,000 miles, there was plenty of material left on the friction plates, it had just hardened with age causing the clutch to slip. I've still got them. They are completely black and very hard compared to a new set. I don't think you have to worry about the clutch leaving you anywhere. Just pay attention to your rpms when you are hard on the thottle to see if you notice any slippage. I replaced mine when it started slipping under heavy throttle above 7000 rpms. It was a couple of weeks to locate and get the parts shipped as I went with a Barnette kevlar clutch kit rather than the stock honda parts. But by the time the parts arrived, it would completely break away above 7000 rpms with any significant throttle. But by my recollection it had been slipping for 3-4 months at that point. Knowing how much you ride the VFR, I'd be proactive and order the parts so you can replace them before it becomes a problem and plan the downtime rather than have it forced. BTW, the cheapest route is to just replace the friction discs as the steels are generally fine unless you cooked the clutch doing drag race launches. The only other thing you need to replace is the judder spring, it's shim and the clutch springs. The judder spring will be weak and need to be replaced otherwise you will end up with the clutch discs bouncing on initial engagement resulting in a juddering action as the plates grab and release due to the bouncing. Replacing the 6 main springs is needed because they have become noticably shorter and weaker as a result of their time in compression. Chris Stumpf _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Thanks Chris. Wouldn't want to leave Olivier stranded this July.
John _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Hash: SHA1 > Thanks Chris. Wouldn't want to leave Olivier stranded this July. > > John You guys worry too much. If it starts slipping there is plenty time to start planning and ordering parts before it becomes unrideable. Instead of worrying what might wear out next, how about riding the damn thing? :) If I started getting my pants in a knot about what might happen when, I'd never get anywhere. Bikes aren't made of sugar and they don't need to be treated as such. Gijs. afterburn http://www.vfr750.com http://www.crashdot.com ICQ: 187800 FJR1300A _____ "The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom." - Isaac Asimov -----BEGIN PGP SIGNATURE----- Version: PGP 8.0.3 iQA/AwUBRAXB9Amn0BNopOB7EQIw7QCg3uigKuBm9qIaZeGw1WvZg3+xumAAoNE7 sAbHzcFKAe4W1MDOPAYDwklL =kWC4 -----END PGP SIGNATURE----- _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
On 3/1/06, Dutch Viffer
> > > > Thanks Chris. Wouldn't want to leave Olivier stranded this July. > > > > John > > You guys worry too much. If it starts slipping there is plenty time > to start planning and ordering parts before it becomes unrideable. > Instead of worrying what might wear out next, how about riding the > damn thing? :) If I started getting my pants in a knot about what > might happen when, I'd never get anywhere. Bikes aren't made of sugar > and they don't need to be treated as such. Gijs, what do you know? You ride like my mother! Besides, it's not like there isn't a spare in the garage! Hey, BTW, I must be turning Dutch. Found a screw in the VFR's rear tire that was going to be replaced this Saturday but I went ahead and plugged it anyway to get 3 more days of riding out of it! John - still lubing my chain boss. ;-) _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
#14 (permalink) |
> > John - still lubing my chain boss. ;-) > Gee, I'm not sure if that comment is worksafe. ;-) Chris Stumpf _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Hash: SHA1 > Gijs, what do you know? You ride like my mother! > > Besides, it's not like there isn't a spare in the garage! > > Hey, BTW, I must be turning Dutch. Found a screw in the VFR's > rear tire that was going to be replaced this Saturday but I > went ahead and plugged it anyway to get 3 more days of riding > out of it! > > John - still lubing my chain boss. ;-) Yeah yeah yeah, try to keeping up this June will ya? ;) Gijs - still laughing afterburn http://www.vfr750.com http://www.crashdot.com ICQ: 187800 FJR1300A _____ "The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom." - Isaac Asimov -----BEGIN PGP SIGNATURE----- Version: PGP 8.0.3 iQA/AwUBRAYOegmn0BNopOB7EQLcJwCg3oUzCE6xGpNTjESY7E4eAUFS/fMAoNci oRziTyYFFxBFl/3AEWrUbYFt =DHJA -----END PGP SIGNATURE----- _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| '07 VFR 800A: first impressions | RedRover5683 | General VFR Discussions | 5 | 04-10-2008 07:57 PM |
| VFR For Sale | Montero, Eddie CDR NAVELSG, N3 | VF/VFR Mailing List | 0 | 03-18-2008 01:54 PM |
| RE: Vfr Digest, Vol 27, Issue 46 | Zenon | VF/VFR Mailing List | 0 | 06-27-2006 02:30 PM |
| New(er) VFR? | Mark Huth | VF/VFR Mailing List | 5 | 06-18-2006 08:04 PM |
| 2003 Clutch Levers | Kyle Allen | VF/VFR Mailing List | 0 | 06-09-2006 10:29 AM |
