Old 03-01-2006, 03:15 PM   #1 (permalink)
Dan Barufaldi
Re: Grab rail bolt removal question (Chris Aschauer)
That's a tough one - the easy-out is harder than the bolt...so, I would try, it it's close to the top, cut a slot in the easy out head, and use a screwdriver to turn it out (clockwise). If that doesn't work, sometimes you can punch the center, and start drilling. Although it will be hard to drill, sometimes the turning of the bit loosens the easy out.
Good luck.
Dan B
>From: John Alexander
>Sent: Mar 1, 2006 4:55 PM
>To: vfr@xxxxxx
>Subject: Re: Grab rail bolt removal question (Chris Aschauer)
>On 3/1/06, MICHAEL BEDDOWS wrote:
>> Tapping if done lightly as i guess you have done doesnt seem to loosen
>> stuborn bolts.
>Any thoughts about how to do it once you have a broken 'EZ Out' in there
>right smack dab in the middle of the bolt. :-(
>John in Calif
Vfr@xxxxxx
Grab Rail Inserts Mick McHam VF/VFR Mailing List 5 01-14-2008 08:01 AM
Grab rail bolts. Saint_Craig Mechanics Garage 1 10-09-2006 08:16 PM
... bolt removal question Dan Barufaldi VF/VFR Mailing List 5 03-02-2006 11:08 AM
re:Grab rail bolt removal question (Chris Aschauer) MICHAEL BEDDOWS VF/VFR Mailing List 1 03-01-2006 02:55 PM
Grab rail bolt removal question Chris Aschauer VF/VFR Mailing List 0 02-28-2006 09:09 PM
