Powder coat wheels
I may be opening a big can of worms here but I need to have the rear wheel on my 98 VFR refinished. I have found a few sources on the web that claim powder coating is bad for aluminum wheels. They claim it ruins the heat treatment when the aluminum exceeds 300 degrees fahrenheit. I have talked to a lot places and they all claim it's fine. I talked to Trans Wheel corp they powder coat their wheels and claim it actually makes the wheel stronger. They claim their repaired wheels will meet or exceed all oem and government crash standards. They claim to have done testing on the wheels they have remanufactured. Trans Wheel is a nationwide company that fixes automotive wheels sort of like Maco. I'm making an assumption that the alloy used in cast car wheels is the same as the one used in motorcycle wheels. I talked to Dymag and RC components and they both offer powder coating although Dymag said their powder cures at 375 degrees. I tried contacting the manufacturer of the VFR wheel!
s Asahi tec but they refuse to answer. Doesn't suprise me as they don't sell to the public. I know I'm not the first to do this. I'm wondering if anyone else has come up with better information. Thanks Tobin _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: Powder coat wheels
I work with a guy that does powdercoating at home (also does it at work). He
did my VFR wheels for me and they turned out fine. I think his oven bakes them at 350 degrees or something, but they are only in there for 15 minutes. He says the wheels probably aren't getting over 275 or 300 degrees in that short of time which won't do anything to the aluminum make-up. If you are interested in contacting him, he does a set (front and rear) for $100 plus shipping in just about any color you want. He can also do the center part of your rotors for $15 each (I changed mine from gold to black), or anything else you want that will fit in a 4' X 4' X 6' oven. E-mail me off the list if you want his contact info. Ken ----- Original Message ----- From: "Tobin S. Bakner" To: Sent: Monday, April 10, 2006 5:38 PM Subject: Powder coat wheels >I may be opening a big can of worms here but I need to have the rear wheel >on my 98 VFR refinished. I have found a few sources on the web that claim >powder coating is bad for aluminum wheels. They claim it ruins the heat >treatment when the aluminum exceeds 300 degrees fahrenheit. I have talked >to a lot places and they all claim it's fine. I talked to Trans Wheel corp >they powder coat their wheels and claim it actually makes the wheel >stronger. They claim their repaired wheels will meet or exceed all oem and >government crash standards. They claim to have done testing on the wheels >they have remanufactured. Trans Wheel is a nationwide company that fixes >automotive wheels sort of like Maco. I'm making an assumption that the >alloy used in cast car wheels is the same as the one used in motorcycle >wheels. I talked to Dymag and RC components and they both offer powder >coating although Dymag said their powder cures at 375 degrees. I tried >contacting the manufacturer of the VFR wheel! > s Asahi tec but they refuse to answer. Doesn't suprise me as they don't > sell to the public. I know I'm not the first to do this. I'm wondering if > anyone else has come up with better information. > > Thanks > > Tobin > > _______________________________________________ > Vfr mailing list > Vfr@xxxxxx > For subscription and delivery options: > https://lists.cs.wisc.edu/mailman/listinfo/vfr > _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
On 4/10/06, Ken Shuart
If you are interested in contacting him, he does a set (front and rear) for > $100 plus shipping in just about any color you want. He can also do the > center part of your rotors for $15 each (I changed mine from gold to > black), > or anything else you want that will fit in a 4' X 4' X 6' oven. > > E-mail me off the list if you want his contact info. Does that include stripping or bead blasting the wheels? John in Calif _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Dunno if it's good or bad...but I had my wheels done about 8 years ago.
No broken or bent wheels, yet. C BTW - brake fluid and powder coating does NOT mix - be careful! Tobin S. Bakner wrote: > I may be opening a big can of worms here but I need to have the rear wheel > on my 98 VFR refinished. I have found a few sources on the web that claim > powder coating is bad for aluminum wheels. They claim it ruins the heat > treatment when the aluminum exceeds 300 degrees fahrenheit. -- ********************************* Chris Merrill cmerrill@xxxxxx ********************************* _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Yes, that includes stripping them. I knocked out my bearings, seals, valve stems, and removed the rotors, but he did the stripping, powdercoating, and clearcoating.
----- Original Message ----- From: John Alexander Cc: vfr@xxxxxx Sent: Monday, April 10, 2006 9:10 PM Subject: Re: Powder coat wheels On 4/10/06, Ken Shuart If you are interested in contacting him, he does a set (front and rear) for $100 plus shipping in just about any color you want. He can also do the center part of your rotors for $15 each (I changed mine from gold to black), or anything else you want that will fit in a 4' X 4' X 6' oven. E-mail me off the list if you want his contact info. Does that include stripping or bead blasting the wheels? John in Calif ------------------------------------------------------------------------------ _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
RE: Powder coat wheels
FWIW, I had my wheels powdercoated back in 2001 and haven't had an issue
since. Later...ROB '99 GL800RR-SP2 Spouse's- '90VTR250 Profile Page: http://profiles.yahoo.com/veefer800canuck Website: http://www.geocities.com/veefer800canuck/index.html _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
There is a local company here that does it for $75 dollars a wheel so
it's relatively cheap. My main concern is if it weakens the wheel. Lots of people and lots of powder coating places say it's fine. Here are 2 articles that say don't do it and one that seems to say it's mostly OK. It seems that powder coating is the most popular option. http://my.execpc.com/~davewrit/Powder.html http://forums.svttexas.com/showthread.php?t=6869 http://www.eng-tips.com/viewthread.c...=151053&page=1 Thanks Tobin _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
I powder coated the wheels (silver) on my '98 VFR shortly after buying it in
1998, but did not clear coat them. Over the next seven years and 24,000+ miles (more than a few at triple-digit speeds) I had no problems with the structural integrity of the wheels, although as someone pointed out yesterday, they were quite vunerable to brake fluid - and to aggresive tire changing . . . Chris Burdett With an Amazing Wife . . . and a Bimota SB6, and a Goldwing 1800A , and just recently a 1974 BMW R90/6, but (sadly) no longer "a '98 VFR with more shit on it than you can shake a stick at . . . " _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| Are the '05 VFR wheels powder coated? | KENJI | Sixth Generation 2002-2009 | 13 | 11-27-2008 07:31 AM |
| Painting 101 | Wesley J | Modifications | 30 | 05-01-2008 06:06 PM |
| Black wheels on an 06 6th Gen??? | VFR02rider | General VFR Discussions | 1 | 03-04-2008 03:52 PM |
| Painted Wheels | Wu-Viffer | Modifications | 18 | 07-25-2006 06:11 PM |
| What Does Chroming Wheels Cost? | VFRDavid008 | Buying & Selling | 2 | 03-31-2004 12:06 PM |
