AutoCom Trunk Mounting?
Finally upgrading my Chatterbox units with a new AutoCom. Had planned on
continuing to use my tankbag as the location, but after reading the manual, I am thinking a bit about permanent mounting on the bike. Question for you AutoCom vets...is trunk mounting really viable? In other words is the system really good enough to use without having access to the knobs? Any tips or thoughts would be appreciated.... Thanks Don Davis 99 VFR800 99 VFR800 01 Tie Fighter _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: AutoCom Trunk Mounting?
Yes. After 6 years of use on my old one ... although mine is in my tank bag
along with radar, music, CB etc. So I can remove easily at stops/for the night and transfer easily between bikes ... Gary Dehner KY Director HSTA; IBA; AMA: BMWMOA: Airheads Lexington, KY '75 R75 /6 '92 Virago, '00 VFR800 ----- Original Message ----- From: Don Davis To: VFR Mailing List (VFR Mailing List) Sent: Friday, May 05, 2006 4:36 AM Subject: AutoCom Trunk Mounting? Finally upgrading my Chatterbox units with a new AutoCom. Had planned on continuing to use my tankbag as the location, but after reading the manual, I am thinking a bit about permanent mounting on the bike. Question for you AutoCom vets...is trunk mounting really viable? In other words is the system really good enough to use without having access to the knobs? Any tips or thoughts would be appreciated.... Thanks Don Davis 99 VFR800 99 VFR800 01 Tie Fighter ------------------------------------------------------------------------------ _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Don Davis wrote:
> Question for you AutoCom vets...is trunk mounting really viable? In > other words is the system really good enough to use without having > access to the knobs? > > Any tips or thoughts would be appreciated.... I have had mine mounted under the seat for a couple of years with power from the tail light circuit. The only time I have needed to access it was to reseat a jack plug which had come loose. There is only one knob on a Pro-7 and it has not needed adjustment after the initial setup. Robert _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
RE: AutoCom Trunk Mounting?
I have mine located in place of the tool bag under the seat, and run the
wires up to put the radio in the tank bag where I can get to the radio knobs. Other than the VOX sensitivity and on the newer ones, the volume gain, there is really nothing to touch ... and these generally stay at the same setting once you set it up. I wrap the unit with stuff like the sell to cushion tool box drawers and hold throw rugs in place (kind of a weave effect with holes to breath), to protect it from shock loads, and put a plastic bag over it for extra rain/water protection. For power I just have a plug system to disconnect it from the battery ... just never got back to move it to a relay controlled circuit, and it lets me use the unit when the key is off (minimal power draw when the radio is off, so it can go several days...or longer... without draining the battery). Best to try to locate it where you can get enough slack on the cables going to the helmet and radio. I've also seen a remote antenna used by screwing a lead on in place of the radio antenna. YMMV Carl -----Original Message----- Finally upgrading my Chatterbox units with a new AutoCom. Had planned on continuing to use my tankbag as the location, but after reading the manual, I am thinking a bit about permanent mounting on the bike. Question for you AutoCom vets...is trunk mounting really viable? In other words is the system really good enough to use without having access to the knobs? Any tips or thoughts would be appreciated.... Thanks Don Davis 99 VFR800 99 VFR800 01 Tie Fighter _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| Autocom 2-way radio | Steve George | VF/VFR Mailing List | 4 | 05-02-2008 03:46 PM |
| If you have to pick one...Trunk or Bags???? | killerkingdon | Sixth Generation 2002-2009 | 39 | 12-05-2007 07:39 AM |
| Autocom NVFRC | Sherman, Larry, GCM | VF/VFR Mailing List | 1 | 04-23-2007 10:31 PM |
| $175 Trunk (mounted) | rossilvr | Sixth Generation 2002-2009 | 1 | 12-03-2006 06:50 PM |
| Valentine One Radar Locator Mounting | Miketegra | Gear & Accessories | 3 | 08-28-2006 12:25 PM |
