Old 05-10-2006, 06:22 PM   #1 (permalink)
Ed Moore
Re: Tubes in tubeless tires
Listers,
AFAIK the major reason that tubes aren't to be used in tubeless radial
tires is the shape of the rim. The rim is designed to capture the bead,
and the air pressure forms the seal. This locks the tire in place.
A tube probably will not create enough pressure to lock the tire in place
for a sufficient fit.
Having said that, I have successfully run tubeless tires with tubes in
bias ply design on wheels designed for bias ply tires.
In any case, except as a very short term solution, I would not get into
the use of tubes in my tubeless radial tire.
Ed Moore
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Vfr@xxxxxx
Conti Road-Attack Tires stephanon2whls Tire Reviews 37 06-05-2008 12:24 PM
Avon Storn ST Tires emon07 Mechanics Garage 8 04-30-2007 06:41 PM
Tires - Dunlop Qualifier Mathew Roth VF/VFR Mailing List 4 10-05-2006 10:16 PM
LCD panel not working ??!?!? Olivier VF/VFR Mailing List 1 02-28-2006 07:07 PM
Initial thoughts on Conti Road-Attack Tires - long but a good readfor tire shoppers stephanon2whls VF/VFR Mailing List 1 02-11-2006 09:05 PM
