K&N filter for '98
Guys,
After waiting nearly a month I finally received my K&N filter for my '98 VFR. The filter in the bike was FILTHY and I just about couldn't ride it anymore for fear of screwing something up. I'm sure it is the original with nearly 14K on it. A couple of things: The K&N seems to have a much smaller filter media area than the stock-type filter. The K&N filter element size has to be only 2/3's the size of the stock. This looks really weird to me as the K&N is supposed to flow so much more freely -wouldn't having the greatest area of filtration help even more? Anyone else notice this on their K&N's? There is just a tiny bit of oil splooge coming out of the rear cylinder air re-breather. Probably less than a 1/4 teaspoon but it is there and there is a slight haze of oil on the plastic around the inlet and up and around the trumpet intake of the right rear throttlebody thingie. I felt down inside and it is just slightly damp from oil residue. I have not noticed any oil consumption or anything like that at oil change. This is such a small amount of oil but enough to show up in the pristine under-filter area as a light misting of oil. Should I be worried about this? The oil seems really clean at least and not black in the slightest bit or smell burnt. I change oil every 3K. Is this something anyone else has seen before? Bike was crashed once (hard) but the frame and wheels are true and straight. Is it possible that something in the rear valve area is throwing oil up and out into the re-breather tube? Jim _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: K&N filter for '98
My take on filtration is that the more surface area, the better the
filtration. Example, I recently purchased a 99 Suburban. I was looking around to see what might need maintenance and one item on my list was the air filter. I had opened it up and saw a red filter and figured the previous owner had spent the money on a K&N. There was no label or sticker telling me so, though. The next week I ordered an AmsOil filter to replace it. I have used K&N in the past, with a Jeep XJ. Though I never had any engine problems, I read more and more about the K&N philosophy. Great marketing, but not the best filters. Filters are supposed to take particles out of the air going directly to your engine's fuel+air mixture system. When the new filter arrived my first impression was that it might be the wrong filter. I removed the FRAM filter, not a K&N. The AmsOil was about an inch larger in diameter and almost a 1/2" longer. There was rubber on each end instead of plastic and the metal framework was substantially heavier construction. Upon inspecting the FRAM closer it had a much more porous filter (determined by looking through the filter in sunlight). The filter also had extremely defined areas that were blocked by what looked like oil and debris. I am not saying that FRAM makes a bad filter, but I have to believe that it was not up to the OEM specifications. Then again, I have no proof of that because I do not know what a GM/Delco filter looks like for this application. What I am trying to say is that you will typically get what you pay for. However, you will definitively know a quality filter when you see it. For the price of K&N, you could buy several OEM filters. I paid more for the AmsOil filter than another FRAM or OEM, but I also know I am getting my money's worth from previous experience. Remember to check the filter periodically, regardless. Your riding conditions will determine how long the filters last. As for the re-breather tube, I have to ask, is that what it is designed to do? One of those tubes is supposed to be drained from time to time... IIRC? Deward R. Knapp, MBA, CCS L E G A C Y Get more information: http://legacybusinessgroup.com Referral Code: 3007152 1+866.236.6115 voice/fax On May 15, 2006, at 1:22 PM, firefly wrote: > Guys, > > After waiting nearly a month I finally received my K&N filter for > my '98 > VFR. The filter in the bike was FILTHY and I just about couldn't ride > it anymore for fear of screwing something up. I'm sure it is the > original with nearly 14K on it. > > A couple of things: > > The K&N seems to have a much smaller filter media area than the > stock-type filter. The K&N filter element size has to be only > 2/3's the > size of the stock. This looks really weird to me as the K&N is > supposed > to flow so much more freely -wouldn't having the greatest area of > filtration help even more? Anyone else notice this on their K&N's? > > Jim _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| WTS Used K&N Air Filter for 5th & 6th Gen VFR | wade _s | Buying & Selling | 4 | 04-26-2008 06:27 AM |
| 2001 VFR K&N air filter ? | Blackhawk28 | Mechanics Garage | 3 | 04-11-2008 11:00 AM |
| K&N Air Filter for older models | ChrisPaegelow | General VFR Discussions | 2 | 03-10-2007 06:03 PM |
| k&n filter ?? | troy | Modifications | 13 | 10-20-2006 09:47 PM |
| Problem after installing K&N Filter?? | woodcycl | Mechanics Garage | 10 | 06-20-2003 05:06 PM |
