THEORY connector bounce problem due to engine vibration
Hello,
A recent gas mileage thread here included opinions that higher RPM operation resulted in improved gas mileage so I have been cruising in 5th gear instead of 6 on my commute. Additionally, I have beem practicing a lot on my favorite twisty/hilly road involving even more high RPM running. In a recent post I commented about how quickly my VFR charging voltage drops off requiring cleaning of the two R/R connectors. My frazzled brain managed to correlate these two issues and recalled a website I visited when I first started using a GPS on my VFR. And thus I offer this theory for consideration. It is a simple extrapolation of the articles linked and excerpted below: Certain frequencies of engine vibration cause the sping tension contacts in the VFR electrical connectors (or any motorcycle) to bounce and arc and over time a carbon residue builds up between the contacts (making then "dirt") and causing resistance in the circuit. The article talks about batteries and coil springs as well as singles and and twins. I am suggesting that the higher vibration frequencies of a 4 cylndar has the same effect on the spring metal contacts of the male/female blade type connetors on a motorcycle as the lower vibration frequencies of a single or twin have on the coil springs used in the AA battery compartment of the GPS. I own both a Garmin III and V and can attest that both are effectivly unuseable in battery mode on the VFR due to the battery bounce phenomenon. I will additionally comment that the failure can occur without residue buildup being visible to the naked eye. However cleaning apparently "dead" batteries with and eraser or emory cloth restores operation, although only briefly. I have excerpted the significant portions of two web pages that my theory is based on and include the links as well. "This discussion is for those trying to run a GPS on a motorcycle, on its internal batteries. This is a battery bounce problem due to engine vibration, primarily on single cyclinder motorcycles, and some twins. The battery problem usually disappears if the GPS is powered from the motorcycle's 12v electrical system" http://www.cycoactive.com/gps/gps_batteries.html " Notice the black deposits on the battery terminals. This is carbon buildup caused by engine vibration. Inside the battery case, the batteries are suspended between two springs. At certain frequencies (RPMs) the batteries jump around and lift off the terminals, creating a small spark each time they disconnect. After thausands of sparkings, a black carbon residue builds up between the contact and the battery terminal. Even though the batteries are not dead, the electricity can't get out thus the GPS thinks they're dead and shuts down. You can scrape the residue off the battery, but it seems to return even faster, and it's difficult to clean the contacts. For this reason we advise using external power right from the start if possible. At the very least tape the batteries and put dielectric grease on the terminals to shut out the oxygen which prevents a burning spark." http://www.cycoactive.com/gps/GPS_ba...2and3plus.html The major weakness in this theory that I see is that I don't know for a fact that engine vibration is readily transmitted into the wiring harness connectors since the connectors themselves are not in direct contact with the frame but only loosely suspended from it by the wiring? Thanks for reading, comments welcomed, Bob _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: THEORY connector bounce problem due to engine vibration
Bob Chappuis wrote:
> I am suggesting that the higher vibration frequencies > of a 4 cylndar has the same effect on the spring metal contacts of > the male/female blade type connetors on a motorcycle as the lower vibration > frequencies of a single or twin have on the coil springs used in the > AA battery compartment of the GPS. Interesting theory, but it's a tough sell to me. I _might_ buy the theory as it relates to batteries in portable electronics, since you have a (relatively) very heavy battery between two lightweight spring contacts. But a blade connector? Maybe if the connector was poorly made such that the metal was _barely_ in contact in the first place - and the metal contanct can vibrate separate of the connector housing. Maybe. -- ********************************* Chris Merrill cmerrill@xxxxxx ********************************* _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
RE: THEORY connector bounce problem due to engine vibration
Some may not believe it, but that can happen in blade connectors. That
would be case of arcing causing the corrosion. The reverse can also occur, where corrosion caused by harsh environments results in arcing. In either case, the arc/corrosion cycle leads to high resistance. The problem can be solved by cleaning the contacts, confirming that they are mating tightly, and packing them with di-electric grease prior to assembly. John Harrison Birmingham > -----Original Message----- > From: vfr-bounces@xxxxxx > [mailto:vfr-bounces@xxxxxx] On Behalf Of Chris Merrill > Sent: Thursday, May 18, 2006 9:58 AM > To: vfr@xxxxxx > Subject: Re: THEORY connector bounce problem due to engine vibration > > Interesting theory, but it's a tough sell to me. I _might_ > buy the theory as it > relates to batteries in portable electronics, since you have > a (relatively) very > heavy battery between two lightweight spring contacts. But a > blade connector? > Maybe if the connector was poorly made such that the metal > was _barely_ in contact > in the first place - and the metal contanct can vibrate > separate of the connector > housing. Maybe. > > > -- > ********************************* > Chris Merrill > cmerrill@xxxxxx > ********************************* > _______________________________________________ > Vfr mailing list > Vfr@xxxxxx > For subscription and delivery options: > https://lists.cs.wisc.edu/mailman/listinfo/vfr > _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Hi Bob,
I can and do accept that this is a possibility where a relatively heavy battery is made contact to by quite light springs, but the connectors used on the bike are very different. The forces exerted by the spade connectors (that's what we call the flat vehicle connectors in the UK) on the sides of the spade is very high when compared to the weight of cable which can vibrate. I would also accept that if these have been removed and refitted several times perhaps becoming loose in the process, that they can then become subject to vibration, poor contact and over heating. There is one effect of heat and vibration worth mentioning, as perhaps some of you have not come across it.... If you solder tin bare wires, then insert then into brass or other metal terminal with a screw to tighten - then the solder can over time, heat and vibration creep out from under the securing screw. Thus it becomes loose, generates heat through its resistance and the deterioration accelerates. So never tin wires before use in a screw terminal, just twist the bare wires or one of those tubular sleeves designed for the job. -----Original Message----- Hello, It is a simple extrapolation of the articles linked and excerpted below: Certain frequencies of engine vibration cause the sping tension contacts in the VFR electrical connectors (or any motorcycle) to bounce and arc and over time a carbon residue builds up between the contacts (making then "dirt") and causing resistance in the circuit. The article talks about batteries and coil springs as well as singles and and twins. I am suggesting that the higher vibration frequencies of a 4 cylndar has the same effect on the spring metal contacts of the male/female blade type connetors on a motorcycle as the lower vibration frequencies of a single or twin have on the coil springs used in the AA battery compartment of the GPS. _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
So have you seen an increase in gas mileage?
I don't care if the engine is more "efficient" at the higher rpm, I don't see how it can give you better gas mileage. The wheels, transmission, and engine are in a simple mechanical ratio. For each mile that the wheels turn, the engine revolves a number of times depending upon the ratio, and a certain amount of fuel goes into the cylinder for each cycle. What, less than 80% as much fuel goes into each cylinder at 7,500 rpm as what goes in at 6,000 rpm? Ed 1998 VFR800 > -----Original Message----- > On Behalf Of Bob Chappuis > > A recent gas mileage thread here included opinions that higher RPM > operation resulted in improved gas mileage so I have been cruising in > 5th gear instead of 6 on my commute. Additionally, I have beem > practicing a lot on my favorite twisty/hilly road involving even more > high RPM running. In a recent post I commented about how quickly my VFR _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
No! I have not see any significant increase in gas mileage. If
anything it down a half a mile per gallon. Cheers, Bob Friday, May 19, 2006, 10:11:27 PM, you wrote: > So have you seen an increase in gas mileage? > I don't care if the engine is more "efficient" at the higher rpm, I don't > see how it can give you better gas mileage. > The wheels, transmission, and engine are in a simple mechanical ratio. For > each mile that the wheels turn, the engine revolves a number of times > depending upon the ratio, and a certain amount of fuel goes into the > cylinder for each cycle. What, less than 80% as much fuel goes into each > cylinder at 7,500 rpm as what goes in at 6,000 rpm? > Ed > 1998 VFR800 >> -----Original Message----- >> On Behalf Of Bob Chappuis >> >> A recent gas mileage thread here included opinions that higher RPM >> operation resulted in improved gas mileage so I have been cruising in >> 5th gear instead of 6 on my commute. Additionally, I have beem >> practicing a lot on my favorite twisty/hilly road involving even more >> high RPM running. In a recent post I commented about how quickly my VFR > _______________________________________________ Vfr mailing list Vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| engine problem with vf500 | asway | First & Second Generation 1983-1989 | 32 | 03-14-2008 05:55 PM |
| Engine dies in mid corner! | Mick McHam | VF/VFR Mailing List | 10 | 05-07-2007 10:09 AM |
| Engine Vibration at 4k rpm plus | blackrifle | VF/VFR Mailing List | 1 | 09-16-2006 09:20 PM |
| Engine Vibration | aussie Bob | Mechanics Garage | 1 | 09-12-2006 12:07 AM |
| 1990 VFR 750 Engine Vibration | ride | Mechanics Garage | 4 | 04-25-2006 08:10 AM |
