ChatBox (New messages since your last visit: 1)
Old 06-09-2006, 10:29 AM   #1 (permalink)
Kyle Allen
2003 Clutch Levers
Anyone recommend a good place to buy clutch lever set/brake lever set for a 2003 Honda VFR?
Also, anyone recommend a good place for fairings? My silver VFR got tipped over! I need a lower left fairing.
Kyle
vfr-request@xxxxxx wrote: Send Vfr mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
vfr-request@xxxxxx
You can reach the person managing the list at
vfr-owner@xxxxxx
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Vfr digest..."
Today's Topics:
1. Re: advice on mounting Fiamm horns? ('94) (firefly)
2. Re: advice on mounting Fiamm horns? ('94) (firefly)
3. RE: advice on mounting Fiamm horns? ('94) (Brad Berson)
4. RE: advice on mounting Fiamm horns? ('94) (Brad Berson)
5. RE: advice on mounting Fiamm horns? ('94) (John Harrison)
6. Re: advice on mounting Fiamm horns? ('94) (firefly)
7. Re: VFR - So Cal (Roger Chase)
8. Re: New Show on Speed: "Super Bikes!" (FH)
9. Re: VFR - So Cal (Demian)
10. Re: VFR - So Cal (Chris Burgess)
11. Re: VFR - So Cal (John Alexander)
12. Re: VFR - So Cal (Chris Burgess)
13. Re: 2002 Olds. Alero (Marc Brinker)
14. NVFRC: I'm out. (Jacob Ezzell)
15. (no subject) (Ian Smith)
16. leaving (GEORGE GILL)
17. Re: leaving (Bob Staaf)
Message: 1
Date: Thu, 08 Jun 2006 10:39:19 -0500
Subject: Re: advice on mounting Fiamm horns? ('94)
To: Brad Berson
Cc: vfr@xxxxxx
Message-ID: <448844A7.4070701@xxxxxx>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Brad Berson wrote:
>There's no clearance on the upper fork legs, no clearance for something
>that size anywhere in the uppers that I can see...
Hogwash.
Sorry that these are ugly pics. These are early shots taken right after
I finished up. Sorry for the ugly electrical tape instead of the nice,
clean tie-wraps it has now and the general filthy nature of the bike
that day. I just got done installing it and I don't generally clean the
bike BEFORE I work on it.
As you can see, with the black plastic filler gone there is plenty of
room ahead of the radiator. There is about 1-1/2 clearance to the fork
at least where it comes closest to it during its swing.
These are thumbnails. Click on picture for larger view if you have the
bandwidth.
target="imagehosting">
src="http://show.imagehosting.us/show/1410179/0/nouser_1410/T1_-1_1410179.jpg"
border="0"/>
src="http://show.imagehosting.us/show/1410188/0/nouser_1410/T1_-1_1410188.jpg"
border="0"/>
src="http://show.imagehosting.us/show/1410191/0/nouser_1410/T1_-1_1410191.jpg"
border="0"/>
src="http://show.imagehosting.us/show/1410197/0/nouser_1410/T1_-1_1410197.jpg"
border="0"/>
Took me about 1 hour to plan out the job and buy the materials and
another hour to do the work on the horn/bracket and another hour to
route the new wires and terminate them at the battery with fuses. While
I was at it I also ran an additional set to the top left side of the
fairing for a future power outlet for a heated vest or whatnot. (Time
not including pulling the bodywork off and putting back on which was the
major PITA of this job).
-Jim
Message: 2
Date: Thu, 08 Jun 2006 10:48:53 -0500
To: vfr@xxxxxx
Message-ID: <448846E5.6010506@xxxxxx>
>Hogwash.
Sorry, messed that up royally...
2nd verse, same as the first (but right this time I hope and without the
thumbnail feature)
http://www.imagehosting.us/index.php...&ident=1410179
http://www.imagehosting.us/index.php...&ident=1410188
http://www.imagehosting.us/index.php...&ident=1410191
http://www.imagehosting.us/index.php...&ident=1410197
-Jim
Message: 3
Date: Thu, 8 Jun 2006 12:07:09 -0400
Subject: RE: advice on mounting Fiamm horns? ('94)
To:
Message-ID:
Content-Type: text/plain; charset="us-ascii"
> Hogwash.
There are some differences between the the stated '94 (through '97) to
which the question originally applied, and your '98, but thanks for
showing your handiwork. If you manage some clearer pictures at some
point do send them up, or make a page about it somewhere. Include some
brief descriptions about the camera angles so people know what they're
looking at.
Also be aware, and I can't say for certain whether this will affect you
since I don't recall how the '98 plastic looks exactly, that very often
what appears to be "filler" or cosmetic pieces are actually spoilers and
are important for directing airflow to places that need it and/or
directing airflow and spray away from areas that would be problematic.
-Brad
Message: 4
Date: Thu, 8 Jun 2006 12:24:30 -0400
To:
Message-ID:
>Hogwash.
As a follow-up to my last reply, it should be noted that on a '94-'97
the area you used to install your horn is occupied by a fuse box, some
plumbing and the black plastic "intake that isn't an intake". Subbing
the horn for the intake still leaves some plumbing interference and is
begging to destroy the horn via water ingestion.
The left side is equally busy with plumbing and cosmetics.
The bad part about my idea inside the left lower is (a) heat from the
headers (easily solved with a heat shield) and the fact that any bracket
there would be a cantilevered arrangement, which if it isn't designed
suitably won't last long in such a high-vibration environment.
-Brad
Message: 5
Date: Thu, 8 Jun 2006 11:25:51 -0500
To: ,
Message-ID: <000c01c68b18$392108a0$1300000a@xxxxxx>
FWIW, leaving a wire where it can chafe on an exposed screw thread (as shown
in the photo) is not good practice and is probably asking for a short
circuit at some point. Hopefully this oversight was corrected when the zip
ties replaced the tape job.
Also FWIW, my 99 runs significantly cooler with the black plastic pieces in
place, so it appears that the engineers at Honda do actually know what they
are doing when designing a bike and the airflow management for it.
John Harrison
Birmingham
> -----Original Message-----
> From: vfr-bounces@xxxxxx [mailto:vfr-bounces@xxxxxx] On Behalf
> Of firefly
> Sent: Thursday, June 08, 2006 10:49 AM
> To: vfr@xxxxxx
> thumbnail feature)
> -Jim
> _______________________________________________
> Vfr mailing list
> Vfr@xxxxxx
> For subscription and delivery options:
Message: 6
Date: Thu, 08 Jun 2006 11:45:35 -0500
To: John Harrison
Cc: vfr@xxxxxx
Message-ID: <4488542F.1050603@xxxxxx>
Yup. Like I said. This was a mock-up job to test the feasibility of the
system. I R an electri-can and do be making many wiring
harnesessifications in the years. This is a teeny-tiny control job
compared to some of the automated plants I've wired. Plus, that is good
THHN wire there and is fused at 15A (holds for a 30 second blast on
test) although that aluminum frame spar isn't physically grounded to the
chassis in any spot so the first "short" would be FREE.
As far as the engine cooling/heat: It's been a non-issue. I'm surprised
at how little the bike needs to run the radiator fan even in Chicago
traffic. Sometimes I get stuck for an hour on the Kennedy and the Edens
only barely moving enough to not have to put my foot down. I keep an
eye on the temp but it's not ever got over 210 and usually is under 200
(way under when under way). I think it IS hogwash myself. My '86 ran
much hotter than the '98 does and the bodywork on that was quite spartan
in comparison. I think that having the radiator up front is actually
worse for airflow than the side-mounted ones regardless of the goofy
black plastic junk honda put up in there.
-Jim
Message: 7
Date: Thu, 8 Jun 2006 11:32:12 -0600
Subject: Re: VFR - So Cal
To: , "VFR List"
Message-ID:
Content-Type: text/plain; charset="iso-8859-1"
I am off the 405 and Beach Blvd in Huntington Beach. See you out there.Roger B. Chase Sr.AMA: 677639HRCA: HRC 300007192http://www.frappr.com/?a=myfrappr&id=140884 Formerly Littleton, CO, Now Huntington Beach, CA1998 Honda VFR800FiChatrboxCB_VFR.@xxxxxx(Just take the excess periods outand you got my email address!)--------------------
Message: 2Date: Wed, 7 Jun 2006 11:06:58 -0700 (PDT)From: Kyle Allen Subject: VFR - So CalTo: vfr@xxxxxxessage-ID: <20060607180658.24373.qmail@xxxxxx>Content-Type: text/plain; charset="iso-8859-1" Any other VFR riders in SoCal? Take tours or rides or know of any groups? Appreciate the love... kyle
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today it's FREE!
http://messenger.msn.click-url.com/g...ave/direct/01/
-------------- next part --------------
An HTML attachment was scrubbed...
URL: http://lists.cs.wisc.edu/archive/vfr...ttachment.html
Message: 8
Date: Thu, 08 Jun 2006 17:55:36 +0000
Subject: Re: New Show on Speed: "Super Bikes!"
To: mike@xxxxxx, vfr@xxxxxx
Message-ID:
<060820061755.9631.448864980000E42C0000259F2207000953CBCDC7080E00@xxxxxx>
Ok, I have seen one of these (fur) deals.. I don't get it.. is that becomming the poor bikers bondo? "you dent it, you Fuzz it" concept??
What Gives?
FH
-------------- Original message ----------------------
> I'm hoping for some shop talk, like how to get the best look when covering
> shattered bodywork with fur, or overcoming electrical gremlins when installing
> neon.
Message: 9
Date: Thu, 08 Jun 2006 11:29:01 -0700
To: Kyle Allen
Cc: vfr@xxxxxx
Message-ID: <44886C6D.7040307@xxxxxx>
> kyle
Yep. I'm in Camarillo.
Demian
Message: 10
Date: Thu, 8 Jun 2006 11:46:58 -0700
To: "Roger Chase"
Cc: VFR List , kylerallen@xxxxxx
Message-ID:
What's "the 405"? I've heard of I-405 or Interstate 405 but never "the
405".
sorry little rant about So Calers.
Message: 11
Date: Thu, 8 Jun 2006 11:51:35 -0700
Cc: "VFR List"
Message-ID:
> 405".
Now you have. ;-)
That the best you can do!
John in Calif
Message: 12
Date: Thu, 8 Jun 2006 12:56:00 -0700
To: "John Alexander"
Cc: VFR List
Message-ID:
Ya its the best I can do.
I'm from Seattle...what I did would make most Seattlites cringe and cry for
their Mommies.
-Chris
> > 405".
> Now you have. ;-)
> John in Calif
> Vfr mailing list
> Vfr@xxxxxx
Message: 13
Date: Thu, 8 Jun 2006 22:33:32 -0400
Subject: Re: 2002 Olds. Alero
To: "Chris Bedard" , "VFR Mail List"
Message-ID: <007801c68b6d$19fc2950$1d02a8c0@xxxxxx>
Dude, at least preface that message subject with "NVFRC" if you're going to spam the list with non-VFR content!
Marc
----- Original Message -----
2002 Olds. Alero GL Coupe.
Message: 14
Date: Thu, 8 Jun 2006 21:59:08 -0600
Subject: NVFRC: I'm out.
To: VFR-List
Message-ID:
The signal to noise ratio has degraded way too far. I'll pop back in to ask
questions I suppose.
Jacob,
Denver
Message: 15
Date: Fri, 09 Jun 2006 08:50:09 +0000
To: Vfr@xxxxxx
Message-ID:
Message: 16
Date: Fri, 9 Jun 2006 10:13:33 +0100 (BST)
Subject: leaving
To: vfr@xxxxxx
Message-ID: <20060609091333.56741.qmail@xxxxxx>
Content-Type: text/plain; charset=iso-8859-1
Please take me off your mailing list. Im getting rid
of my vf750sc as I cannot get parts for it.
Send instant messages to your online friends http://uk.messenger.yahoo.com
Message: 17
Date: Fri, 09 Jun 2006 06:47:12 -0400
Subject: Re: leaving
To: GEORGE GILL , vfr@xxxxxx
Message-ID: <016401c68bb3$3aa73000$0200a8c0@xxxxxx>
Uhhh guys, read the bottom of every email sent through the list. You can
unsubscribe yourself from the list......
To:
Sent: Friday, June 09, 2006 5:13 AM
Subject: leaving
> Vfr mailing list
> Vfr@xxxxxx
Vfr mailing list Vfr@xxxxxx
End of Vfr Digest, Vol 27, Issue 11
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Vfr@xxxxxx
Brake and clutch levers eurofixer General VFR Discussions 3 07-21-2008 10:52 PM
Rebuilding Slave Cylinder Fixed My Clutch rjhartmann Mechanics Garage 1 04-07-2008 06:08 AM
Pazzo Brand clutch and brake levers James Bair VF/VFR Mailing List 3 07-12-2007 05:01 PM
Clutch wear; Sad but true. Jeremy Boron VF/VFR Mailing List 6 06-02-2006 07:19 AM
RE: Vfr Digest, Vol 23, Issue 24 Jeremy Boron VF/VFR Mailing List 3 02-27-2006 08:38 AM
