NVFRC ; question- "fork seal install"
Listers,
I am seeking wisdom / experience of the list to problem solve a condition that exsists. As a multi-bike owner/rider, I do most the work on them myself,& mostly comes out right, though frequently will find several wrong ways to do things before stumbling on the right way. These problem arose this past winter, I changed a fork seal on my 86 G/Wing and the removal and inspection went without problem .I took the leg to a local shop where the wrench used a seal driver to seat the seal, then I took it home, added fork oil ,and reinstalled the leg and wheel. I was stunned to find when I began riding it again,the leg still leaked. I tried adding air to the forks, didn't help.The fork tube looked/felt fine, and though it doesn't leak as bad as the old seal, it still leaks enough to drip after a short ride (running down toward the brake pads).. not good. I'm thinking maybe leaks/ doesn't seal as it should as I got the seals from the local shop & they were aftermarket (non OEM) seals.and of ? quality. I also wondered if it was necessary for the wrench to slam the seal driver as hard as he did when seating the seal in the leg. I recall thinking he seemed to be a little over -enthusiastic when driving the seal in with the seal driver. Any thoughts on this ? (I ordered a new set of OEM seals for my GL 1200, but havn't put them on yet.) Wanting to avoid another session of taking everytning apart (more than once) on my ST, I ordered the OEM seals and thought I'd send you this to request advice/seek opinions on what went wrong/why seal leaks. (experience can be a good teacher) and had any advice to offer ?... Maybe I should add, though I havn't done it recently, I've changed fork seals many times in the past ,on both dirt & street bikes, and have never had a new seal not perform well after I changed it. Iv'e got leaking seals on the GL,ST, and an XR200 I bought this spring for my youngest son to ride, all needing fork seals. Your suggestions/thoughts /ideas are welcome. My VFR And VTR aren't leaking...though the HD FXEF is starting to weep too! (must be all the potholes &frost upheaveals in S.E.Mich.) Thanks in advance for responding...Joebiker996. _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
RE: NVFRC ; question- "fork seal install"
When I brought my '97 VFR to the local shop to rectify a blown left fork
seal, they recommended I order bushings as well as seals. They said that bushing wear is often a big contributor to failed seals. -Brad _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: NVFRC ; question- "fork seal install"
You probably already do this, but I'll mention it anyway. When done with a
ride, or on a long trip, wipe the tubes down with some Wubya-Dee-4-tee (WD-40). Dirt, and dried bugs can take a seal out in one stroke. It may be he drove the seal in with too much force. I use the old seal, by cutting out a small section (so I can get it back out), then use it as a buffer between the new seal, and the tool. TK ----- Original Message ----- From: "Joe Speed" To: Sent: Wednesday, August 02, 2006 9:58 AM Subject: NVFRC ; question- "fork seal install" > Listers, > I am seeking wisdom / experience of the list to problem solve a condition > that exsists. > As a multi-bike owner/rider, I do most the work on them myself,& mostly > comes out right, though > frequently will find several wrong ways to do things before stumbling on the > right way. > > These problem arose this past winter, I changed a fork seal on my 86 G/Wing > and the removal and inspection went without problem .I took the leg to a > local shop where the wrench used a seal driver to seat the seal, then I took > it home, added fork oil ,and reinstalled the leg and wheel. > I was stunned to find when I began riding it again,the leg still leaked. I > tried adding air to the forks, didn't help.The fork tube looked/felt fine, > and though it doesn't leak as bad as the old seal, it still leaks enough to > drip after a short ride (running down toward the brake pads).. not good. > I'm thinking maybe leaks/ doesn't seal as it should as I got the seals from > the local shop & > they were aftermarket (non OEM) seals.and of ? quality. I also wondered if > it was necessary for the wrench to slam the seal driver as hard as he did > when seating the seal in the leg. I recall thinking he seemed to be a little > over -enthusiastic when driving the seal in with the seal driver. > Any thoughts on this ? > > (I ordered a new set of OEM seals for my GL 1200, but havn't put them on > yet.) > > Wanting to avoid another session of taking everytning apart (more than once) > on my ST, I ordered the OEM seals and thought I'd send you this to request > advice/seek opinions on what went wrong/why seal leaks. (experience can be a > good teacher) and had any advice to offer ?... > > Maybe I should add, though I havn't done it recently, I've changed fork > seals many times in the past ,on both dirt & street bikes, and have never > had a new seal not perform well after I changed it. Iv'e got leaking seals > on the GL,ST, and an XR200 I bought this spring for my youngest son to ride, > all needing fork seals. Your suggestions/thoughts /ideas are welcome. > My VFR And VTR aren't leaking...though the HD FXEF is starting to weep too! > > (must be all the potholes &frost upheaveals in S.E.Mich.) > > Thanks in advance for responding...Joebiker996. > > > _______________________________________________ > vfr mailing list > vfr@xxxxxx > For subscription and delivery options: > https://lists.cs.wisc.edu/mailman/listinfo/vfr > _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Yup, I'm with them on this one.
TK ----- Original Message ----- From: "Brad Berson" To: Sent: Wednesday, August 02, 2006 10:12 AM Subject: RE: NVFRC ; question- "fork seal install" > When I brought my '97 VFR to the local shop to rectify a blown left fork > seal, they recommended I order bushings as well as seals. They said > that bushing wear is often a big contributor to failed seals. > > > -Brad > > _______________________________________________ > vfr mailing list > vfr@xxxxxx > For subscription and delivery options: > https://lists.cs.wisc.edu/mailman/listinfo/vfr > _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Hate to say it, but if the installer was ham fisted with the seal driver,
there is a good chance that he did not take care to protect the new seal when he slid it over the fork leg. I usually wrap the top of the leg with electrical tape and grease the seal to make sure that it does not get damaged during installation. John Harrison Birmingham > -----Original Message----- > From: vfr-bounces@xxxxxx [mailto:vfr-bounces@xxxxxx] On Behalf > Of Tom Komjathy > Sent: Wednesday, August 02, 2006 12:18 PM > To: Joe Speed; vfr@xxxxxx > Subject: Re: NVFRC ; question- "fork seal install" > > You probably already do this, but I'll mention it anyway. When done with a > ride, or on a long trip, wipe the tubes down with some Wubya-Dee-4-tee > (WD-40). Dirt, and dried bugs can take a seal out in one stroke. > It may be he drove the seal in with too much force. I use the old seal, > by > cutting out a small section (so I can get it back out), then use it as a > buffer between the new seal, and the tool. > > TK > ----- Original Message ----- > From: "Joe Speed" > To: > Sent: Wednesday, August 02, 2006 9:58 AM > Subject: NVFRC ; question- "fork seal install" > > > > Listers, > > I am seeking wisdom / experience of the list to problem solve a > condition > > that exsists. > > As a multi-bike owner/rider, I do most the work on them myself,& mostly > > comes out right, though > > frequently will find several wrong ways to do things before stumbling on > the > > right way. > > > > These problem arose this past winter, I changed a fork seal on my 86 > G/Wing > > and the removal and inspection went without problem .I took the leg to a > > local shop where the wrench used a seal driver to seat the seal, then I > took > > it home, added fork oil ,and reinstalled the leg and wheel. > > I was stunned to find when I began riding it again,the leg still leaked. > I > > tried adding air to the forks, didn't help.The fork tube looked/felt > fine, > > and though it doesn't leak as bad as the old seal, it still leaks enough > to > > drip after a short ride (running down toward the brake pads).. not good. > > I'm thinking maybe leaks/ doesn't seal as it should as I got the seals > from > > the local shop & > > they were aftermarket (non OEM) seals.and of ? quality. I also wondered > if > > it was necessary for the wrench to slam the seal driver as hard as he > did > > when seating the seal in the leg. I recall thinking he seemed to be a > little > > over -enthusiastic when driving the seal in with the seal driver. > > Any thoughts on this ? > > > > (I ordered a new set of OEM seals for my GL 1200, but havn't put them on > > yet.) > > > > Wanting to avoid another session of taking everytning apart (more than > once) > > on my ST, I ordered the OEM seals and thought I'd send you this to > request > > advice/seek opinions on what went wrong/why seal leaks. (experience can > be > a > > good teacher) and had any advice to offer ?... > > > > Maybe I should add, though I havn't done it recently, I've changed fork > > seals many times in the past ,on both dirt & street bikes, and have > never > > had a new seal not perform well after I changed it. Iv'e got leaking > seals > > on the GL,ST, and an XR200 I bought this spring for my youngest son to > ride, > > all needing fork seals. Your suggestions/thoughts /ideas are welcome. > > My VFR And VTR aren't leaking...though the HD FXEF is starting to weep > too! > > > > (must be all the potholes &frost upheaveals in S.E.Mich.) > > > > Thanks in advance for responding...Joebiker996. > > > > > > _______________________________________________ > > vfr mailing list > > vfr@xxxxxx > > For subscription and delivery options: > > https://lists.cs.wisc.edu/mailman/listinfo/vfr > > > > > _______________________________________________ > vfr mailing list > vfr@xxxxxx > For subscription and delivery options: > https://lists.cs.wisc.edu/mailman/listinfo/vfr _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| nvfrc BMW F650CS oil change question | T | VF/VFR Mailing List | 4 | 11-09-2007 01:28 PM |
| NVFRC seat belt question | Mathew Roth | VF/VFR Mailing List | 2 | 11-01-2006 10:31 AM |
| NVFRC: seatbelt question | Ron Perrillo | VF/VFR Mailing List | 1 | 11-01-2006 08:57 AM |
| Fork seal question | Quint A Marcaletti | VF/VFR Mailing List | 2 | 03-09-2006 03:47 PM |
| NVFRC: RE: XM antenna question | Eric Jaramillo | VF/VFR Mailing List | 0 | 02-27-2006 08:34 PM |
