Old 08-20-2006, 01:13 AM   #1 (permalink)
D. L. Young
Carb Question
Hello All,
Coming out of lurk mode for a bit with a quick carb question.
I have a 96 VFR that has sat for most of the last two and half
years. I would ride it occasionally but it started running rough
so I stopped riding it altogether until I could pull the carbs
and clean them. I tried the Techron route but it didn't help so I
have pulled the carbs out and am getting ready to do a full tear
down and clean.
My question is, where are the air mixture screws hiding? The
parts fiche shows a screw set that looks to be the air mixture
screws but it is very vague as to where it goes. When I did the
carbs on my V65 Sabre they were behind a little metal plug but
what I thought was the metal plug looks like it just plugs a
through passage.
Thanks in advance for any help, I want to make sure to get them
out before I dip the carb bodies and ruin the oring that's in
there.
Speed Safe,
Don
96 VFR
San Diego,CA
Fuel injector/carb cleaner (was: Baseline carb setting for stock 94) Ed Kokosa VF/VFR Mailing List 3 04-09-2008 11:18 AM
Carb maintenance update ... Olivier Gerouville VF/VFR Mailing List 0 01-29-2008 12:10 AM
carb adjustment question Christopher Stumpf VF/VFR Mailing List 4 01-25-2008 11:16 AM
carb question hater81 Mechanics Garage 1 12-14-2007 08:18 AM
Carb fuel line routing question... dlman First & Second Generation 1983-1989 7 03-05-2007 07:40 PM
