starter valves synching
Hi all-
What would be the symptoms of the starter valves needing to be synched? I'm trying to narrow down what's causing my slight engine flutter and so far have ruled out valve adjustment and faulty coils. thanks- RP chicago _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
RE: starter valves synching
Starter valves? Do you mean the carburetors balanced/synchronized?
If you are getting an unsteady idle, this is likely the cause .... Even if it is one of the fuel injected bikes, they need to have their throttle bodies synchronized (balanced air-flow at idle) to let the engine run smoothly. You didn't mention what year, so I made it general. Carl _____ From: vfr-bounces@xxxxxx [mailto:vfr-bounces@xxxxxx] On Behalf Of Ron Perrillo Sent: Wednesday, August 30, 2006 4:29 PM To: vfr@xxxxxx Subject: starter valves synching Hi all- What would be the symptoms of the starter valves needing to be synched? I'm trying to narrow down what's causing my slight engine flutter and so far have ruled out valve adjustment and faulty coils. thanks- RP chicago _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: starter valves synching
On Wednesday 30Aug, 2006, at 4:59 PM, Walzer, Carl (.) wrote:
> Subject: starter valves synching > > Hi all- > > What would be the symptoms of the starter valves needing to be > synched? I'm trying to narrow down what's causing my slight engine > flutter and so far have ruled out valve adjustment and faulty coils. > RP > Starter valves? Do you mean the carburetors balanced/synchronized? > > If you are getting an unsteady idle, this is likely the cause .... > Even if it is one of the fuel injected bikes, they need to have > their throttle bodies synchronized (balanced air-flow at idle) to > let the engine run smoothly. You didn't mention what year, so I > made it general. > > Carl Symptoms of poor carburetor or throttle-body synchronization include: uneven idle unsteady engine speed at steady throttle (feels like the pavement is a bit rough, or your throttle hand is trembling) harsh transitions from open- to closed-throttle, particularly on deceleration If it's really bad, it can noticeably affect your fuel consumption. later, Johnj _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| Starter valves? | Kuehl Cory J | VF/VFR Mailing List | 7 | 05-14-2008 08:51 PM |
| 86 VFR700 Starter Problem | dirtbiker525 | First & Second Generation 1983-1989 | 17 | 01-05-2008 12:38 PM |
| starter prob | possum2082 | Mechanics Garage | 0 | 09-13-2007 08:52 PM |
| starter valve sync vs. valves adjustment? | mk01 | Mechanics Garage | 2 | 07-10-2007 02:28 PM |
| RE:RE: Starter Valve Synching | Ron Perrillo | VF/VFR Mailing List | 0 | 08-31-2006 10:46 AM |
