Helibar Install Question
I'm installing helibars on my '00 and have just about finished. I noticed
that the bars have no mechanism inside the tubes that allow you to attached the bar weights. I bought these used from someone who supposedly never installed them. Is this piece normally included or does it have to be purchased separately??? __________________________ Mick McHam Houston, TX '01 ST1100 ABS, STOC# 1134 '00 VFR800FI http://www.hal-pc.org/~mmcham _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: Helibar Install Question
You need to remove the insert (the actual weight) from the stock bars, and
install these in the Heli Bars. There are a couple of retainer clips catching the holes in the ends of the bars. Use a small screwdriver or punch to press the clips in, while pulling the weight out. A little bit of dish soap on the rubbers make the installation a little easier. Subject: Helibar Install Question > I'm installing helibars on my '00 and have just about finished. I noticed > that the bars have no mechanism inside the tubes that allow you to > attached > the bar weights. I bought these used from someone who supposedly never > installed them. Is this piece normally included or does it have to be > purchased separately??? _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
>> and install these in the Heli Bars. There are a couple of retainer clips catching the holes in the ends of the bars. Use a small screwdriver or punch to press the clips in, while pulling the weight out. A little bit of dish soap on the rubbers make the installation a little easier. << Thanks Matt. Sounds like it would be easy to screw up the clips as you come out with it. What's the best procedure to do this? The way I have it envisioned is to screw a bolt part way in the insert (so I can have something to pull with), soap it up as you suggested, then pry on the clips while pulling. Might be handy to have 3 hands! Is there any trick to this or a way to keep from screwing up the clips? __________________________ Mick McHam Houston, TX '01 ST1100 ABS, STOC# 1134 '00 VFR800FI http://www.hal-pc.org/~mmcham _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| Helibar install | Dudealicious | Body Modifications | 13 | 11-24-2008 06:56 PM |
| Helibar Adjustment Question | Bunky | Modifications | 7 | 05-26-2008 05:11 AM |
| "Post" Helibar installation question | whistler | Modifications | 10 | 03-25-2008 06:23 PM |
| helibar install question | gogator | Mechanics Garage | 1 | 06-24-2007 08:02 PM |
| Voltmeter install question | woody77 | Mechanics Garage | 7 | 04-21-2007 04:10 PM |
