Old 09-16-2006, 10:09 PM   #1 (permalink)
Ed Ostack
tapping
I have 25,000 miles on the VFR. Occasionally it provides a tapping sound that goes away as engine RPM increases to 2000. It does not always seem to occur. It comes and goes. The previous owner assured me that it had its valves set in the shop. It seems like it could be a single valve tapping. does anyone have some inputs on this? When coming to a stop, it may.... or may not.... occur.
Ed in Pgh
Old 09-16-2006, 10:20 PM   #2 (permalink)
John Johnson
Re: tapping
> Ed in Pgh
Does it go away if you squeeze the clutch lever?
later,
Johnj
Old 09-17-2006, 09:54 AM   #3 (permalink)
Kevin Glick
RE: tapping
There that's the magic question. Basket rattle and it's normal on any VFR
with reasonable milage.
kev
Kevin Glick--kglick@xxxxxx(The Isle O'Manhattan--NYC)
LRRS/CCS EXPERT# 56///US Marshals Risk And Track Safety Management
Crew 94' EX500(Race)//98' VFR800Fi (Sequoia)// "Keep Thine Eye On
The Tach And Thine Ear On The Engine Lest Thy Whirlybits
Seek Communion With The Sun" John 4:50
_____
John Johnson
Sent: Sunday, September 17, 2006 12:20 AM
To: VFR LIST
Subject: Re: tapping
may not.... occur.
Ed in Pgh
later,
Johnj
Old 09-17-2006, 10:48 AM   #4 (permalink)
blackrifle
RE: tapping
Kev~
Can you please explain this "basket rattle" a little more for those of us
who slept through class? :)
Mike
From: vfr-bounces@xxxxxx [mailto:vfr-bounces@xxxxxx]On Behalf Of
Kevin Glick
Sent: Sunday, September 17, 2006 11:55 AM
To: 'John Johnson'; 'VFR LIST'
Subject: RE: tapping
kev
Of John Johnson
To: VFR LIST
Ed in Pgh
later,
Johnj
Old 09-17-2006, 11:00 AM   #5 (permalink)
John Johnson
Re: tapping
On Sunday 17Sep, 2006, at 12:48 PM, blackrifle wrote:
> Kev~
> of us who slept through class? :)
> Mike
The clutch in your VFR (and many other motorcycles) uses many clutch
plates. one set is splined on the inside, the other on the outside.
The inner splines engage the clutch center (which is directly
attached to the engine) and the outer splines (on that other set of
plates) engages the clutch "basket". That basket is geared on the
outside and drives the transmission.
Because the fit of the plate splines to the basket isn't perfect,
when the bike is in neutral it will rattle. It can rattle under
certain other conditions (e.g. if the basket is excessively worn, but
with only 15k miles on the VFR, this is _extremely_ unlikely) as
well. The rattle goes away when you squeeze the clutch lever because
that disconnects the basket from the vibrations transmitted by the
engine.
In my 90-96VFR750 manual, the diagram is on p. 9-5. The basket is #8,
and the center is #9.
later,
johnj
Old 09-18-2006, 03:36 PM   #6 (permalink)
John Alexander
Re: tapping
On 9/17/06, John Johnson wrote:
> Because the fit of the plate splines to the basket isn't perfect, when the
> bike is in neutral it will rattle. It can rattle under certain other
> conditions (e.g. if the basket is excessively worn, but with only 15k
> miles on the VFR, this is _extremely_ unlikely) as well. The rattle goes
> away when you squeeze the clutch lever because that disconnects the basket
> from the vibrations transmitted by the engine.
Be glad you don't have a dry clutch!
JohnA in LA
Old 09-18-2006, 04:48 PM   #7 (permalink)
John Johnson
Re: tapping
> but with only 15k miles on the VFR, this is _extremely_ unlikely)
> as well. The rattle goes away when you squeeze the clutch lever
> because that disconnects the basket from the vibrations transmitted
> by the engine.
Everyone says that people buy Ducati's for the sound, isn't this what
they're talking about?
later,
Johnj
Old 09-18-2006, 07:47 PM   #8 (permalink)
t
Re: tapping
My K100RS had a single plate dry clutch...I didn't
recall it making anywhere near as much noise as my VFR
does.
1996 VFR750F
1991 Prelude Si
2006 Flying Ford Anglia
Old 09-18-2006, 11:06 PM   #9 (permalink)
John Johnson
Re: tapping
> does.
I don't really know much about it, since all my motorcycles have had
wet clutches. I do know that lots of folks mention the rattle of
Ducati's clutches. I'd guess that a dry single-plate clutch (which
IIRC most BMW motorcycles have) would rattle less than a multi-plate
clutch. Ducati's current range is full of dry multi-plate clutches,
so that's my guess.
I also know that I forgot to put a smiley in the last post. :-)
later,
Johnj
Old 09-18-2006, 11:10 PM   #10 (permalink)
Chris Burgess
Re: tapping
My BMW's clutch never rattled. Even when it exploded. :)
> > does.
> so that's my guess.
> later,
> Johnj
Check out my racing site...http://www.chrisburgess.com/
Tapping sound from my VFR. . . John VF/VFR Mailing List 6 07-05-2007 10:50 PM
Engine Tapping Noise + Low Power KonradM Mechanics Garage 7 08-05-2006 12:21 PM
VF 500 tapping noise reg71 Mechanics Garage 9 08-04-2006 03:32 PM
