RE: Ilmor V4 - more info... nVFRc
If the valves are pneumatically operated, what does the camshaft do?
Wouldn't the control of the valves be accomplished with a crankshaft position sensor and the engine management computer? Ed "happy with gear whine" and 1998 VFR 800 "The engines are four-valve, twin-cam designs with gear-driven valves are pneumatically operated." _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: Ilmor V4 - more info... nVFRc
I think this means the valve "springs" are pneumatic. Apparently eliminating the "float" inherent at high rpm with traditional springs.
----- Original Message ----- From: Ed Kokosa To: vfr@xxxxxx Sent: Friday, October 06, 2006 10:28 PM Subject: RE: Ilmor V4 - more info... nVFRc If the valves are pneumatically operated, what does the camshaft do? Wouldn't the control of the valves be accomplished with a crankshaft position sensor and the engine management computer? Ed "happy with gear whine" and 1998 VFR 800 "The engines are four-valve, twin-cam designs with gear-driven camshafts, and the valves are pneumatically operated." ------------------------------------------------------------------------------ _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Hello Ed ~
With pneumatically operated valves, the conventional valve springs are simply replaced with pneumatic (or "air") springs. The camshafts serve the same purpose as with a conventional setup. Andy Bertsch '99VFR800FI/Sargent Cogito Ergo Zoom Sidney, Ohio abertsch1@xxxxxx Message: 14 Date: Fri, 6 Oct 2006 22:28:40 -0400 From: "Ed Kokosa" Subject: RE: Ilmor V4 - more info... nVFRc To: Message-ID: <200610070228.k972SnuX014097@xxxxxx> Content-Type: text/plain; charset="us-ascii" If the valves are pneumatically operated, what does the camshaft do? Wouldn't the control of the valves be accomplished with a crankshaft position sensor and the engine management computer? _____ I am using the free version of SPAMfighter for private users. It has removed 6564 spam emails to date. Paying users do not have this message in their emails. Try SPAMfighter _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Is that what "pneumatically operated" means, for this engine, and also for
F1 engines? I always thought "operated" meant "operated", i.e., opened and closed. So these are mechanically opened, pneumatically closed (although the mechanical portion also controls the closing rate/position). Is the pneumatic "spring" closed, or is it subject to a constant (or varying) pressure created by a pump on the engine? Ed _____ From: Andrew Bertsch [mailto:abertsch1@xxxxxx] Sent: Saturday, October 07, 2006 8:00 AM To: Ed Kokosa Cc: VFR Mailing List Subject: RE: Ilmor V4 - more info... nVFRc Hello Ed ~ With pneumatically operated valves, the conventional valve springs are simply replaced with pneumatic (or "air") springs. The camshafts serve the same purpose as with a conventional setup. Andy Bertsch Message: 14 Date: Fri, 6 Oct 2006 22:28:40 -0400 From: "Ed Kokosa" If the valves are pneumatically operated, what does the camshaft do? Wouldn't the control of the valves be accomplished with a crankshaft position sensor and the engine management computer? _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Ed ~
Follow the link below for a cursory explanation of pneumatic valve actuation. This site doesn't answer all of your questions, but it's worth a visit nonetheless. http://www.delwestusa.com/manufactur...tic_valves.asp Andy Bertsch '99VFR800FI/Sargent Cogito Ergo Zoom Sidney, Ohio abertsch1@xxxxxx -----Original Message----- From: Ed Kokosa [mailto:edk800f1@xxxxxx] Sent: Saturday, October 07, 2006 9:35 AM To: 'VFR Mailing List' Cc: 'Andrew Bertsch' Subject: RE: Ilmor V4 - more info... nVFRc Is that what "pneumatically operated" means, for this engine, and also for F1 engines? I always thought "operated" meant "operated", i.e., opened and closed. So these are mechanically opened, pneumatically closed (although the mechanical portion also controls the closing rate/position). Is the pneumatic "spring" closed, or is it subject to a constant (or varying) pressure created by a pump on the engine? Ed _____ From: Andrew Bertsch [mailto:abertsch1@xxxxxx] Sent: Saturday, October 07, 2006 8:00 AM To: Ed Kokosa Cc: VFR Mailing List Subject: RE: Ilmor V4 - more info... nVFRc Hello Ed ~ With pneumatically operated valves, the conventional valve springs are simply replaced with pneumatic (or "air") springs. The camshafts serve the same purpose as with a conventional setup. Andy Bertsch Message: 14 Date: Fri, 6 Oct 2006 22:28:40 -0400 From: "Ed Kokosa" If the valves are pneumatically operated, what does the camshaft do? Wouldn't the control of the valves be accomplished with a crankshaft position sensor and the engine management computer? _____ I am using the free version of SPAMfighter for private users. It has removed 6564 spam emails to date. Paying users do not have this message in their emails. Try SPAMfighter _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| Re: NVFRC Spamfighter info pls | Grant Gathagan | VF/VFR Mailing List | 0 | 08-28-2007 03:32 AM |
| NVFRC Spamfighter info pls. | Steve \Spider\ Enfield | VF/VFR Mailing List | 0 | 08-27-2007 04:24 PM |
| NVFRC: Race to Dakar - was NVFRC: Fastest Indian | Leo Matikainen | VF/VFR Mailing List | 2 | 01-13-2007 06:59 AM |
| NVFRC please help with info on 2002 Tarago GLI | VF/VFR Mailing List | 0 | 12-05-2006 11:23 PM | |
| RE: (NVFRC) Looking for good info on Drill Press | Pap | VF/VFR Mailing List | 0 | 12-05-2006 12:36 PM |
