Old 10-11-2006, 10:35 AM   #1 (permalink)
Mrydr
Re: Question / Archived Threads / SID... / Actually SED Thread....
In a message dated 10/11/2006 8:59:06 A.M. Eastern Daylight Time,
VFR@xxxxxx writes:
As for charging-system and upgrades, I don't think the charging-system
shortcomings would cause this, but you might want to check the wiring in and
immediately around the battery-box for corrosion.
Thanks Ari,
I tried originally searching with SID but I steered you wrong, I meant SED.
As mentioned my mind ain't what it used to be......
I found this in the archives:
_https://lists.cs.wisc.edu/archive/vfr/2002-July/msg00984.shtml_
(https://lists.cs.wisc.edu/archive/vf...msg00984.shtml)
There was a big discussion on this list which spilled into more details on
the VTEC board.
Apologies to Nisar Naseeruddin in my previous post, as mentioned, the old
gray matter ain't what she used to be.....
I hope this helps, good luck.
Fred
The definitive Gen 5 Vs Gen 6 weight Thread John451 General VFR Discussions 10 03-24-2008 05:18 PM
Re: Question / Archived Threads / SID... Mrydr VF/VFR Mailing List 1 10-11-2006 06:59 AM
Re: thread thread StlthHsta VF/VFR Mailing List 0 08-24-2006 08:08 PM
NVFRC: RE: XM antenna question Eric Jaramillo VF/VFR Mailing List 0 02-27-2006 08:34 PM
