Old 10-24-2006, 05:34 PM   #1 (permalink)
Travis
SSS rear axle rebuild
After 110,000+ miles and occasionally getting both wheels off the ground, my
rear bearings are done. How do you know when the bearings are done? First
you notice what sounds like a squeaky rear brake. Then you notice some side
play in the rear wheel, so you check the lug nuts only to find they are
perfectly tight. Then at low speeds you start to feel a little wobble in
the rear. It goes away with speed though. Also you will see rusty powder
around the big nut.
So last week I put in an order with Service Honda for all the bearings and
seals. I haven't received them yet, but today I started to disassemble
everything. I figured my Big Ass adjustable wrench would be big enough.
Nope, but dremeling in another notch and cutting away some of the adjuster
screw allowed it to open just enough. I got the nut and driven
sprocket/cush drive bits off, and popped off the big snap ring on the right
side. But the bearing holder/eccentric adjuster assembly just won't pull
out. Turning it with the chain adjust tool helped to get it out a little
more so it is about .5" out.
Is it necessary to do some heavy duty hammering with a Big Ass hammer? It
seems like the bearing holder and axle have become one.
Travis '95 RC36 '01 SV650S '04 DR650 '85 VF500F
'97 RC36 donor about to lose its entire swingarm.
'03 SV1000 race bike FOR SALE
Old 10-24-2006, 06:14 PM   #2 (permalink)
Paul Monti
RE: SSS rear axle rebuild
Travis:
If the 17 mm(?) bolt that pinches the swingarm around the bearing carrier is
loose enough, that thing should just come right out. A big screwdriver or
other wedge could open it up slightly more, if that's the issue. But there
could be some junk built up in there. Fine sand can get in through the
split in the back of the swingarm and could be contributing because there's
a little space that goes all around the carrier. Or the carrier itself
could have some corrosion on it.
>From what you describe I'd be in there with the PB Blaster and Big Ass
hammer (with a piece of hardwood).
Hope this helps. Oh, watch the parts. Some Honda manuals have error in the
section dealing with this procedure.
Paul
> right
> It
Checked by AVG Free Edition.
Version: 7.1.408 / Virus Database: 268.13.11/493 - Release Date: 10/23/2006
Old 10-24-2006, 09:46 PM   #3 (permalink)
John Alexander
Re: SSS rear axle rebuild
> It
Did this last year and noted that the large nut becomes pretty much fused
with the axle after a while. A nice piece of ash helped in my case to
persuede the two apart. Good luck, but it does not take long after that
point.
JohnA in LA
Old 10-25-2006, 07:10 AM   #4 (permalink)
Paul Monti
John
When I first read the post from Travis I thought he was referring to a
problem getting the axle out of the driven flange/driven sprocket hub. This
is the issue that you are referring to, and this is where I had most of the
problems when I did this job. I got a nice piece of ash to help me, too.
But from Travis’ description, he’s gotten those pieces apart and is now
dealing with getting the bearing carrier out. I wouldn’t have thought this
would be a problem, but obviously there is something funky going on there.
Paul
point.
JohnA in LA
Version: 7.1.408 / Virus Database: 268.13.11/496 - Release Date: 10/24/2006
Old 10-25-2006, 10:52 AM   #5 (permalink)
John Alexander
On 10/25/06, Paul Monti wrote:
> John
> But from Travis' description, he's gotten those pieces apart and is now
> dealing with getting the bearing carrier out. I wouldn't have thought this
Good point Paul
A word to the wise on this. I did my rear end before therer were problems
with the bearings.
So, it was just a matter of getting in there and regreasing the bunch.
I recommend doing this by the 75k threshold.
Oh, and hit the outer nut now and then with some WD-40. It likes to freeze
up.
JohnA in LA
Old 11-07-2006, 05:57 PM   #6 (permalink)
Travis
----- Original Message -----
Paul,
You're right about that PB Blaster. In the meantime I ended up just using
the entire swingarm from Matt Roth's old bike. I was later able to get off
the part the cush drive rides on, but that was it. Yesterday I picked up
some PB Blaster and soaked it for 24 hours. Tonight I wailed on it a few
times with a 2x4 and the axle finally came out. One of these days I'll get
around to putting it back together and swapping swingarms again. It looks
like the spare swingarm's axle isn't in very good condition either. The
spacer just inboard of the big nut seems to be solidly fused to everything
around it, at least it doesn't rotate in an oval shape. That swingarm has
less than 50,000 miles. I won't worry about that for now.
Picking up an '83 DT-80K in RI this weekend :-)
Anyone confirm 3G axle and rear wheel nut torque? dale-j Mechanics Garage 2 04-23-2008 11:59 PM
Bent Rear Axle pjc General VFR Discussions 36 03-31-2008 08:34 PM
Rear Axle Cap benjammer General VFR Discussions 2 02-19-2008 08:23 PM
forks vejesse First & Second Generation 1983-1989 45 01-28-2008 11:51 PM
Honda Hawk NT 650 rear axle DOUGLAS COOK VF/VFR Mailing List 2 01-22-2008 12:26 PM
