RE: Castellated shock collar preload adjustment
My KX250 had the dual castelated aluminum collars for shock adjustment
preload. A word to the wise: banging on such collars with a hammer and punch while there is spring tension on them really messes them up quickly. A better approach is to take a pair of spring compressors and compress the spring first. Then the collars can be adjusted by hand. I'm not sure if there's enough room to get at a shock on a VFR with spring compressors, but if possible it's a much better tactic (if you can't use a spanner). HTH, Jake -----Original Message----- Have to disagree with Chris here. I have a Penske with the Traxxion adjustment collar on my 3rd Gen. Here's how it works: Unlike some others, the Penske shock has a preload adjustment collar that is actuated by inserting a steel rod which comes with the shock (about 3/16" dia. x 6" L) into holes located around the collar's periphery. Some others have a castlelated collar that is actuated by a hook spanner. Worse yet, some others (Fox?) have two castlelated collars that are intended to jam to lock the collars in place (never understood the need for this). On the VFR, there are two ways to adjust the castlelated style collar. The first is to remove the battery box with all that implies. Not very appealing when you consider that initially setting the sag might take a few turning sessions. The second, and hamfisted option, is to use a large punch or screw driver and bang away though the small side port in the frame where the old Showa worm screw adjuster used to reside. Also not particulary appealing when you consider that the collar is aluminum alloy on a shock that you just paid $800 for (actually a little less for an 8981). The Traxxion collar functions just like the original Penske item but has twice as many holes around the periphery. Having the additional holes allows adjustment in smaller increments. One can insert the rod into the collar through the side port in the frame and get enough swing to bring the next adjustment hole into reach of the rod. With the original collar you couldn't bring the collar around far enough to get the rod into the next hole. Yes, it's somewhat tedious but not nearly as much as removing the battery box. And once you have your sag set it only takes a few holes worth of adjustment if you want to compensate for a pillion or other heavy load. In the interest of full disclosure, this description applies to the 3rd gen. Also, I trimed about 1/4 inch off the end of the adjustment rod so that it would actually clear the inside edge of the access port to allow for a little more swing. Not necessary but made things even easier. On the 4th gen YMMV. But I think the access port is a similar size. I've enjoyed the Penske so much that I was motivated to do an F3 fork internals transplant and install new tapered roller steering head bearings. Sweet. Traxxion are great to deal with. No affiliation, etc. HTH. Richard Ronay _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: Castellated shock collar preload adjustment
On Tuesday 5Dec, 2006, at 9:18 AM, Jake Harsha wrote:
> My KX250 had the dual castelated aluminum collars for shock adjustment > preload. A word to the wise: banging on such collars with a hammer > and > punch while there is spring tension on them really messes them up > quickly. > Traxxion sells a torrington bearing kit for this. It's a steel washer and a roller bearing (rollers arrayed radially). The bearing goes under their shim, with the spring on top of it. It's supposed to make things easier to spin. Whether that's a good thing, in the absence of a lock-nut, I really don't know. > A better approach is to take a pair of spring compressors and compress > the spring first. Then the collars can be adjusted by hand. I'm not > sure if there's enough room to get at a shock on a VFR with spring > compressors, but if possible it's a much better tactic (if you > can't use > a spanner). I don't see spring compressors being an option unless you pull everything out of the way (battery, batt. box, rear wheel, etc.). At that point, I just wouldn't be adjusting the spring. later, johnj _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
John Johnson wrote:
> Traxxion sells a torrington bearing kit for this. It's a steel washer > and a roller bearing (rollers arrayed radially). The bearing goes > under their shim, with the spring on top of it. It's supposed to make > things easier to spin. Whether that's a good thing, in the absence of > a lock-nut, I really don't know. ________________________ Mine came with the bearing set-up. No special order required. It's actually the needle bearing sandwiched between two flat races (shims). The whole thing then rests between the collar and top of the spring. It still needs some force to turn once the load starts rising. Doesn't seem to be any danger of unwinding on its own. Richard Ronay _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| Ohlins Shock Install | Puma Cat | Suspension Articles | 27 | 02-05-2008 06:22 AM |
| Rear shock / Elka | Tony Shelver | VF/VFR Mailing List | 1 | 10-28-2007 02:23 PM |
| Ohlins Shock Install | michael | Suspension Articles | 9 | 09-19-2007 01:43 PM |
| Rear shock options for 4G | John Johnson | VF/VFR Mailing List | 5 | 12-11-2006 11:35 AM |
| Traxxion/Penske shock | Quint A Marcaletti | VF/VFR Mailing List | 0 | 12-05-2006 07:20 AM |
