Re: Won't start... OK, wouldn't start / Eclectical System Voltages???
In a message dated 2/12/2007 10:14:29 P.M. Eastern Standard Time,
bikemike@xxxxxx writes: I used an electric jacket and heated grips on my ride. As an eclectician, did you take any onboard VOM readings? What were the voltages? Scenario........... Given the VFR charging system is not the most robust, the electric jacket and heating grips did not allow net charging to the battery. @ destination, there was enough juice to enable (ignition, FI, ECU) the VFR to be bump started. Was your ride home colder? LOL. This allowed the battery to get charged, enough to start the bike @ home and then to restart again later. What is the rest voltage of the battery? 12.5-6VDC, if healthy and fully charged it should be high 12s even low 13s. Now is the time to learn about the VFR charging system and not, somewhere a long way from home, US, during riding season. Check out this link (the link through VFR World is not working.....) _http://web.archive.org/web/20040902080147/http://www.yft.org/tex_vfr/tech/rr- maintenance.htm_ (http://web.archive.org/web/200409020...aintenance.htm) Though it describes the 94-97 model, the complexity still remains in the Gen 5. Even though the wiring looks fine, check out the connectors (break/make) and check for signs of corrosion. As Bob mentions, an onboard VOM is highly recommended. Good Luck, HTH Fred in CT w/ Ver. 96 _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
| Two Brothers V.A.L.E. System Review - 6th Gen | whiteboyslo | Exhaust Reviews | 9 | 03-26-2008 11:57 AM |
