help
I have sold my VFR - please unsubscribe me.
Thanks A *** Attention *** This electronic mail including attachments is intended only for the person(s) or entity to which it is addressed and may contain confidential and/or legally privileged material and information. Unauthorized disclosure, copying, distribution or use of this material and information may be unlawful and is prohibited. If you are not the intended recipient and have received this mail in error, please contact the sender and delete all contents of the e-mail as well as any copies made. Thank you! Message from vfr-request@xxxxxx@cs.wisc.edu received on 22-03-2007 17:25 22-03-07 17:25 vfr-request@xxxxxx@cs.wisc.edu Please respond to vfr@xxxxxx Sent by vfr-bounces@xxxxxx To: vfr@xxxxxx cc: Subject: vfr Digest, Vol 36, Issue 26 Send vfr mailing list submissions to vfr@xxxxxx To subscribe or unsubscribe via the World Wide Web, visit https://lists.cs.wisc.edu/mailman/listinfo/vfr or, via email, send a message with subject or body 'help' to vfr-request@xxxxxx You can reach the person managing the list at vfr-owner@xxxxxx When replying, please edit your Subject line so it is more specific than "Re: Contents of vfr digest..." Today's Topics: 1. Givi (Quint A Marcaletti) 2. FW: Givi (Quint A Marcaletti) 3. RE:WTB: Givi luggage (frugalyankee-cycles@xxxxxx) 4. WTB: Givi Luggage (Mathew Roth) 5. RE: vfr Digest, Vol 36, Issue 25 (Quint A Marcaletti) 6. Re: vfr Digest, Vol 36, Issue 25 (Fred Wills) 7. RE: WTB: Givi luggage (Kirk) 8. RE: Givi (Kirk) 9. RE: Wheel repair was: RE: Where have I been all of VFR's life? (Kirk) 10. Since we're on the luggage subject...what about OEM hard bags and top box? (Kirk) 11. Re: FW: Givi (vic5491@xxxxxx) ---------------------------------------------------------------------- Message: 1 Date: Thu, 22 Mar 2007 11:32:13 -0400 From: Quint A Marcaletti Subject: Givi To: "vic5491@xxxxxx" Cc: "vfr@xxxxxx" Message-ID: <20070322113213313.00000002928@xxxxxx> Content-Type: text/plain; charset="us-ascii" Generator Microsoft Word 11 (filtered) I have the E21 side bags and the 460 ( I think that' s the number) top case. Advice: Do not load the top trunk with anything of much weight. Keep that as low as possible. Also, hope you have a stiffer than stock spring out back, unless you are very light! Start loading the rear down and handling goes to hell in a hurry. If not, adjusting preload fully up will help some. Also, you will notice increased headshake/instability with additional rear weight. Tapered head bearings help mine tremendously. If you get the top trunk, I' d recommend the brake-light kit as well. because the standard brake light gets sort-of hidden between the luggage. Anything bigger than the e21 side cases starts getting a bit unwieldy and ugly, IMO. The Givi luggage is awesome for water-proof storage that' s easily removed, and installed. Its durable, and lockable. I love it. QAM -------------- next part -------------- An HTML attachment was scrubbed... URL: http://lists.cs.wisc.edu/archive/vfr...ttachment.html ------------------------------ Message: 2 Date: Thu, 22 Mar 2007 11:33:03 -0400 From: Quint A Marcaletti Subject: FW: Givi To: "vic5491@xxxxxx" Cc: "vfr@xxxxxx" Message-ID: <20070322113303470.00000002928@xxxxxx> Content-Type: text/plain; charset=iso-8859-1 I have the E21 side bags and the 460 ( I think that's the number) top case.? ? Advice:? Do not load the top trunk with anything of much weight.? Keep that as low as possible.? Also, hope you have a stiffer than stock spring out back, unless you are very light!? Start loading the rear down and handling goes to hell in a hurry.? If not, adjusting preload fully up will help some.? Also, you will notice increased headshake/instability with additional rear weight.? Tapered head bearings help mine tremendously.? If you get the top trunk, I'd recommend the brake-light kit as well.because the standard brake light gets sort-of hidden between the luggage.? ?Anything bigger than the e21 side cases starts getting a bit unwieldy and ugly, IMO. ? The Givi luggage is awesome for water-proof storage that's easily removed, and installed.? Its durable, and lockable.? I love it. QAM ------------------------------ Message: 3 Date: Thu, 22 Mar 2007 08:34:51 -0700 (PDT) From: Subject: RE:WTB: Givi luggage To: vfr800 vfr800 Message-ID: <400462.43588.qm@xxxxxx> Content-Type: text/plain; charset="iso-8859-1" Have used the RKA soft system (saddle & tank)since I got mine in '99. Yearly tours from CT. to New Hampshire have worked out very well. Easy to mount & remove, holds alot and have been very gentle on the bike over the years (nothing broken or scratched). They ride much lower than the hardbag systems. Requires a suspension adjustment (shock spring preload and damping) when loaded up to keep proper front end feel. Brad CT. 99 VFR -------------- next part -------------- An HTML attachment was scrubbed... URL: http://lists.cs.wisc.edu/archive/vfr...ttachment.html ------------------------------ Message: 4 Date: Thu, 22 Mar 2007 11:37:40 -0400 From: "Mathew Roth" Subject: WTB: Givi Luggage To: Cc: vic5491@xxxxxx Message-ID: Content-Type: text/plain; charset="us-ascii" I have two Givi E360 momokey cases and SWMotech removeable rack from twistedthrottle.com. I bought the cases used. I like them, though they will get heavy with pillion and fully loaded--need to set the preload appropriately and adust the shock to suit fully loaded riding. That said, I prefer to travel light for long trips...I go with what John (In LA) Alexander says, one change of major clothes, at least two extra pair of socks and underwear (just in case), and a full set of outerwear for ALL likely conditions (mountains get cold in the summer even). I prefer a small two-person tent to a bivy bag as well and you can make a homemade alcahol stove out of a pepsi can if you need to... Always check out the lightweight backpacking sights if you want to reduce what you bring yet still have what you need... BTW the SWMotech rack is beefy, but I haven't put enough miles on it to see if it holds up better than the Givi or not...maybe at one of the VFR rally's I can compare racks... Matt Roth -------------- next part -------------- An HTML attachment was scrubbed... URL: http://lists.cs.wisc.edu/archive/vfr...ttachment.html ------------------------------ Message: 5 Date: Thu, 22 Mar 2007 11:42:53 -0400 From: Quint A Marcaletti Subject: RE: vfr Digest, Vol 36, Issue 25 To: "vfr@xxxxxx" Message-ID: <20070322114253173.00000002928@xxxxxx> Content-Type: text/plain; charset=us-ascii John wrote: "Wash it out at night, it's dry in the morning. And off we go." John...that might happen in LA where its nice and dry....Out east, we have to deal with humidity. Wash a t-shirt out in a sink on a summer day, and 2 days later, its still damp...and moldy! Then you have to pack your damp and moldy shirt in with the rest of your luggage and get it moldy. It sux!! An air-conditioned hotel room will help to dry those clothes, but not much. QAM 2000VFR ------------------------------ Message: 6 Date: Thu, 22 Mar 2007 12:01:06 -0400 From: Fred Wills Subject: Re: vfr Digest, Vol 36, Issue 25 To: "quint.marcaletti@xxxxxx" Cc: "vfr@xxxxxx" Message-ID: <4602A842.2070804@xxxxxx> Content-Type: text/plain; charset=ISO-8859-1; format=flowed Quint A Marcaletti wrote: >John wrote: > >"Wash it out at night, it's dry in the morning. And off we go." > >John...that might happen in LA where its nice and dry....Out east, we have to deal with humidity. Wash a t-shirt out in a sink on a summer day, and 2 days later, its still damp...and moldy! Then you have to pack your damp and moldy shirt in with the rest of your luggage and get it moldy. It sux!! An air-conditioned hotel room will help to dry those clothes, but not much. > > > > Quint, One word for you: Plastics. Get the polypropelene tee-shirts, underwear, etc. Dry much faster and give more comfort in hot conditions as it wicks moisture better than natural cotton fiber. And to allow just a tad of thread drift, here's a tip that I "recycled" from my human-powered cycling days: I highly recommend the use of lycra/spandex bicycling shorts in lieu of your regular BVDs, especially for longer trips. They are way more comfortable in the saddle and can easily be hand washed in the evening and be ready for re-wear the next day. They can be bought with various padding materials including gel inserts, or plain with no "chamois" at all if you prefer. -- -Fred W '98 Honda VFR800Fi SPORTtourer '01 Kawi Concours sportTOURER '05 Yammi FJR1300 SPORTTOURER ------------------------------ Message: 7 Date: Thu, 22 Mar 2007 11:06:07 -0500 From: "Kirk" Subject: RE: WTB: Givi luggage To: Message-ID: <003101c76c9c$0545b1a0$0300a8c0@xxxxxx> Content-Type: text/plain; charset="us-ascii" Which RKA bags are you using, and did you need anything special to add/attach them? Tks, Kirk Texas 1997 VFR -----Original Message----- From: vfr-bounces@xxxxxx [mailto:vfr-bounces@xxxxxx] On Behalf Of frugalyankee-cycles@xxxxxx Sent: Thursday, March 22, 2007 10:35 AM To: vfr800 vfr800 Subject: RE:WTB: Givi luggage Have used the RKA soft system (saddle & tank)since I got mine in '99. Yearly tours from CT. to New Hampshire have worked out very well. Easy to mount & remove, holds alot and have been very gentle on the bike over the years (nothing broken or scratched). They ride much lower than the hardbag systems. Requires a suspension adjustment (shock spring preload and damping) when loaded up to keep proper front end feel. Brad CT. 99 VFR -------------- next part -------------- An HTML attachment was scrubbed... URL: http://lists.cs.wisc.edu/archive/vfr...ttachment.html ------------------------------ Message: 8 Date: Thu, 22 Mar 2007 11:08:50 -0500 From: "Kirk" Subject: RE: Givi To: Message-ID: <003601c76c9c$647b2b00$0300a8c0@xxxxxx> Content-Type: text/plain; charset="us-ascii" Man, you guys are starting to scare me now with this top trunk weight issue. That is something I would have never thought of? Geez It's whole new ay of thinking. In that case, I would really like to know what all of the options are. Kirk Texas 1997 VFR -----Original Message----- From: vfr-bounces@xxxxxx [mailto:vfr-bounces@xxxxxx] On Behalf Of Quint A Marcaletti Sent: Thursday, March 22, 2007 10:32 AM To: vic5491@xxxxxx Cc: vfr@xxxxxx Subject: Givi I have the E21 side bags and the 460 ( I think that's the number) top case. Advice: Do not load the top trunk with anything of much weight. Keep that as low as possible. Also, hope you have a stiffer than stock spring out back, unless you are very light! Start loading the rear down and handling goes to hell in a hurry. If not, adjusting preload fully up will help some. Also, you will notice increased headshake/instability with additional rear weight. Tapered head bearings help mine tremendously. If you get the top trunk, I'd recommend the brake-light kit as well.because the standard brake light gets sort-of hidden between the luggage. Anything bigger than the e21 side cases starts getting a bit unwieldy and ugly, IMO. The Givi luggage is awesome for water-proof storage that's easily removed, and installed. Its durable, and lockable. I love it. QAM -------------- next part -------------- An HTML attachment was scrubbed... URL: http://lists.cs.wisc.edu/archive/vfr...ttachment.html ------------------------------ Message: 9 Date: Thu, 22 Mar 2007 11:12:40 -0500 From: "Kirk" Subject: RE: Wheel repair was: RE: Where have I been all of VFR's life? To: "'Mathew Roth'" Message-ID: <004501c76c9c$efa3b5d0$0300a8c0@xxxxxx> Content-Type: text/plain; charset="us-ascii" 6 weeks!!! NO!! Please no!! Not now! I wanna ride! I don't think mine is that bad, but will soon find out. Thanks for all of the info folks! Kirk Texas 1997 VFR -----Original Message----- From: Mathew Roth [mailto:mroth@xxxxxx] Sent: Thursday, March 22, 2007 9:23 AM To: vfr@xxxxxx Cc: kirk.allen@xxxxxx Subject: Wheel repair was: RE: Where have I been all of VFR's life? These guys fixed my rear wheel: www.framestraightsystem.com I've also talked to these guys as well: http://www.mcwheel.com/ and they have a good rep too. Drawback is you have to send your wheel (sans tire) to them to get it fixed and sometimes (like now - Spring) the turnaround is long (4-6 weeks). Try to find a wheel repair place locally. These guys in Cali repair wheels, but not moto-specific.however they'll chrome it for you too!!! http://www.pppwheels.com/about_us.htm These guys are in Napa and do work on wheels and frames--Moto specific.. http://gpframeandwheel.com/services.html If you look around enough I'd bet you can find someone who can do the work.Best of luck. BTW have you double-checked that the Tire is not the problem? My rear was bent very badly, but it still held air on the bead. the front is still bent, but not enough for me to worry about it too much--however, the tires held air and I hit a very big pothole.might be worth getting out some soapy water and see what bubbles up just to be sure your sidewall of the tire is crap.safety issue possibly Just my 2cents. Matt Roth 1999 VFR800 2000 SV650 trackday bike.Wayne Beaver is my Hero! -------------- next part -------------- An HTML attachment was scrubbed... URL: http://lists.cs.wisc.edu/archive/vfr...ttachment.html ------------------------------ Message: 10 Date: Thu, 22 Mar 2007 11:19:33 -0500 From: "Kirk" Subject: Since we're on the luggage subject...what about OEM hard bags and top box? To: "Vfr@xxxxxx Wisc. Edu" Message-ID: <005401c76c9d$e6540600$0300a8c0@xxxxxx> Content-Type: text/plain; charset="us-ascii" I have seen Viffers in that past with what I have always presumed to be Honda OEM hard bags, that match the color of the bike. (mostly red) If Honda did make hard bags for them, was it only for certain years? Are they still available? What's the dealy? Thanks, Kirk Texas 1997 VFR ------------------------------ Message: 11 Date: Thu, 22 Mar 2007 09:24:05 -0700 (PDT) From: "vic5491@xxxxxx" Subject: Re: FW: Givi To: "quint.marcaletti@xxxxxx" Cc: "vfr@xxxxxx" Message-ID: <108222.13791.qm@xxxxxx> Content-Type: text/plain; charset="iso-8859-1" Thanks for the input Quint! I do appreciate it. I have the stock shock and spring and I am not light (210 lbs) and I definately do not want to compromise handling. I'll keep an eye on all of these issues. Vic Quint A Marcaletti I have the E21 side bags and the 460 ( I think that's the number) top case. Advice: Do not load the top trunk with anything of much weight. Keep that as low as possible. Also, hope you have a stiffer than stock spring out back, unless you are very light! Start loading the rear down and handling goes to hell in a hurry. If not, adjusting preload fully up will help some. Also, you will notice increased headshake/instability with additional rear weight. Tapered head bearings help mine tremendously. If you get the top trunk, I'd recommend the brake-light kit as well.because the standard brake light gets sort-of hidden between the luggage. Anything bigger than the e21 side cases starts getting a bit unwieldy and ugly, IMO. The Givi luggage is awesome for water-proof storage that's easily removed, and installed. Its durable, and lockable. I love it. QAM --------------------------------- It's here! Your new message! Get new email alerts with the free Yahoo! Toolbar. -------------- next part -------------- An HTML attachment was scrubbed... URL: http://lists.cs.wisc.edu/archive/vfr...ttachment.html ------------------------------ _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr End of vfr Digest, Vol 36, Issue 26 *********************************** _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: help
On Sat March 24 2007 6:07 am, adam.roscoe@xxxxxx wrote:
> I have sold my VFR - please unsubscribe me. > > Thanks > > A send the request to your mother. I am sure she will be happy to take care of your responsibilities for you. She is probably accustomed to it by now. -- Jerry Give our Constitution to iraq. They need one and we aren't using ours. _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: help
Oh boy it starting again...here we go
----- Original Message ----- From: "jerry" To: Sent: Saturday, March 24, 2007 7:32 AM Subject: Re: help > On Sat March 24 2007 6:07 am, adam.roscoe@xxxxxx wrote: >> I have sold my VFR - please unsubscribe me. >> >> Thanks >> >> A > > send the request to your mother. > > I am sure she will be happy to take care of your responsibilities for you. > > She is probably accustomed to it by now. > > -- > > Jerry > > Give our Constitution to iraq. They need one and we aren't using ours. > _______________________________________________ > vfr mailing list > vfr@xxxxxx > For subscription and delivery options: > https://lists.cs.wisc.edu/mailman/listinfo/vfr > _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
Re: Help
Adam, asking the list to unsubscribe you will certainly lead to a sentence similar to that given Sisyphus. (see Sisyphus in Websters New World Dictionary if you are not familiar with the tale.) To avoid this, go to https://lists.cs.wisc.edu/mailman/listinfo/vfr
and unsubscribe yourself. You are the only one who can do so. Hope this helps. Vic > On Sat March 24 2007 6:07 am, adam.roscoe@xxxxxx wrote: >> I have sold my VFR - please unsubscribe me. >> >> Thanks --------------------------------- Food fight? Enjoy some healthy debate in the Yahoo! Answers Food & Drink Q&A. _______________________________________________ vfr mailing list vfr@xxxxxx For subscription and delivery options: https://lists.cs.wisc.edu/mailman/listinfo/vfr |
