Old 04-10-2007, 01:49 PM   #1 (permalink)
my rc36
VFR rotors correction...
I guess I can use the front rotor (s) from a 1990 -1997 VFR.
Thanks if anyone has one or two for me.
Please email.
Peter
Old 04-10-2007, 02:40 PM   #2 (permalink)
Walzer, Carl (.)
RE: VFR rotors correction...
I could be wrong, but I believe the '90-'93 is without the floating rotors,
mounting hard to the wheel. The '94+ have (semi) floating rotors with the
buttons on them. I don't think they are interchangeable.
You could also try a search of the archives for straightening rotors. I
think it was Kevin Glick who did a nice write up on how to get them straight
again, assuming they aren't out a huge amount. Note that you will likely
need to do the procedure a couple times (the write up mentions this) as the
metal will relax back when it gets warm, so you need to work it in steps.
Good luck
Carl
_____
my rc36
Sent: Tuesday, April 10, 2007 3:50 PM
To: vfr@xxxxxx
Subject: VFR rotors correction...
Please email.
Peter
Old 04-11-2007, 11:20 AM   #3 (permalink)
J Richard Ronay
Re: VFR rotors correction...
Can't use 90-93 rotors on 94-97. Quite different.
94-97 rotors are the same ones used on the 95-97 CBR 900 RR. If you look on ebay under that listing you will usually find some.
Richard Ronay
----- Original Message -----
To: vfr@xxxxxx
Sent: Tuesday, April 10, 2007 3:49 PM
Please email.
Peter
'07 VFR 800A: first impressions RedRover5683 General VFR Discussions 5 04-10-2008 07:57 PM
VFR For Sale Montero, Eddie CDR NAVELSG, N3 VF/VFR Mailing List 0 03-18-2008 01:54 PM
RE: vfr Digest, Vol 30, Issue 55 Andrew Bertsch VF/VFR Mailing List 5 09-26-2006 05:38 PM
95 VFR fork size Ed Ostack VF/VFR Mailing List 3 09-18-2006 06:45 PM
Re: vfr Digest, Vol 28, Issue 12 David Thompson VF/VFR Mailing List 0 07-17-2006 08:00 AM
