Model: 1982-83 Honda VF400F ENGINE Type: 399 cc, V4, 4-stroke Cooling: Liquid Bore x Stroke: 55 mm x 42 mm Compression Ratio: 11:1 Power: 55.5 hp (41.4 kW) @ 12500 rpm Torque: 35.5 Nm (26.2 ft. lbs) @ 10500 rpm Transmission: 6 speed WHEELS Front Tire: 100/90-16 Rear Tire: 110/90-18 Front Brakes: Single disc Rear Brakes: Single disc DIMENSIONS Length: 2060 mm (81.1 inches) Width: 750 mm (29.5 inches) Height: 1160 (45.7 inches) Seat Height: 780 mm (30.7 inches) Wheelbase: 1415 mm (55.7 inches) Ground Clearance: 160 mm (6.3 inches) Fuel Capacity: 4.5 gallons Dry Weight: 173 kg (381.4 pounds) Original List Price: $6,211 US DESCRIPTION The first model of the V-Four 400cc. It was "Naked style" with bikini-cowling that looked like "MVX250".
