1984 VF1000F- very weak spark on 2&4
Discussion in 'Mechanics Garage' started by wpbarlow, Sep 20, 2017.
  1. wpbarlow
    wpbarlow New Member
    Central New Jersey
    The spark on cylinders 2&4 of my not so nice VF is very weak- will lightly spark directly to ground, but not with the plug cap on. Checked all pertinent wires for shorts/condition and they seem ok.
    Swapped all ignition parts between 1&3 and 2&4 and the good spark always stays with 1&3. Metered the pulse generator and the coils are coming in at 500 Ohms for both sets (spec says should be ~480), and the gap is within spec at .025. So that shouldn't be the problem, but I'm pretty much at a loss as what to do next.
    Totally puzzled by this, so any help would be appreciated.
    Also-- does anyone have an extra pulse generator; or know if one from another model would work?
    thanks,
    Walter
    Do you mean that with the plug cap off the wire, it sparks to ground great, but when you put cap and plug on, it is weak? Sounds like it is time for new plug caps. If I read that wrong, I still think it is time for caps, you can clip the integrated cap off the wire and install new NGK caps. Do it all the time.
    You can also replace all of the wire by unscrewing at the coil.
  3. wpbarlow
    wpbarlow New Member
    Central New Jersey
    The spark, even with the caps off the wires is very weak. But I'm going to get some new wires anyway. The reason I don't think that's the problem is that the problem stays with the cylinders even after swapping the coils.
    After I take a day to think about things, so I don't find a cliff to push it off LOL
    Walter
  4. Terry Smith
    New Zealand
    If the problem stayed on those cylinders, then the fault would be in the supply or ground to the coil primary circuit. Does the 1000F use two CDI boxes? Have you checked for high resistance in the supplying wires?
  5. wpbarlow
    wpbarlow New Member
    Central New Jersey
    I'll be checking all that tomorrow.
    thanks,
    Walter
  6. wpbarlow
    wpbarlow New Member
    Central New Jersey
    Not to keep folks in suspense, but it might be a week or so before I get to this.
    Walter
  7. squirrelman
    sometimes helps to cut about 1/8 " off the wire into the ignition coil to get fresh, clean wire.
  8. wpbarlow
    wpbarlow New Member
    Central New Jersey
    Good idea, thanks.
    Walter
  9. wpbarlow
    wpbarlow New Member
    Central New Jersey
    I'm starting to believe the CDI box may be bad. A friend found this:
    http://www.v4spark.com/
    Sounds good and decent price for a pair. Anyone have experience with them?
    Thanks,
    Walter
  10. Mind_Surfer
    Mind_Surfer New Member
    VA
    Walter I use those on my 500. High quality units and are programmable to some extent.
    Sent from my XT1031 using Tapatalk
  11. wpbarlow
    wpbarlow New Member
    Central New Jersey
    Thanks for the feedback-- I ordered a pair.
    Walter
    Mind_Surfer likes this.
  12. slovcan
    slovcan New Member
    Annapolis Valley, NS, Canada - IBA #63720
    V4Spark is Tom - aka dualcam - a member on our V4Hondabbs site and V4Musclebike site. He's a great guy who makes a top quality product. Even bikes that are running fine end up running better with these spark boxes.
    Cheers,
    Glenn
    Allyance and Mind_Surfer like this.
  13. wpbarlow
    wpbarlow New Member
    Central New Jersey
    Well, delivery was certainly fast enough! Ordered Tuesday and arrived today.
    Installing tomorrow with fingers crossed.
    Walter
  14. wpbarlow
    wpbarlow New Member
    Central New Jersey
    Replaced the CDI boxes and that did the trick- started right up and it ran well considering it hasn't in at least 3 years. Still some relatively minor work to do; but I have high hopes to be on the road in a week.
    The clicking is the fuel pump (not the valves lol) because we're running on gravity feed.
    Here's the first start up
