1990 VFR project
Discussion in 'General VFR Discussions' started by bentleyss, Mar 12, 2018.
  1. bentleyss
    bentleyss New Member
    Englewood, Florida
    Just bought this off craigslist and brought it home Sunday. Complete but in pieces. Giant “model “ kit. Will be posting progress as I go. Previous owner had starting issues. Bike would not power on when ignition on and starter depressed . Sometimes it would ,sometimes not. He replaced battery...and found shoes under seat that he fixed. I suspect possible RH switch is faulty. Anyway I’ll keep this site informed of my progress. The previous owner started to dismantle it for parts on Ebay but didn’t get to it.so Luckily I got the whole bit to try to re-assemble.
  2. Terry Smith
    New Zealand
    Good luck with this. If the starter solenoid isn't getting power then you need to check the kill switch and starter button, the neutral switch and the side-stand and clutch switches. Under normal conditions (in neutral), the clutch and sidestand switch are unimportant.
  3. bentleyss
    Englewood, Florida
    Thanks Terry , will do.
