2002 VFR800 Starting Problem. Engine will not crank.
Discussion in 'Mechanics Garage' started by BlackKnight12, Dec 16, 2011.
  1. BlackKnight12
    BlackKnight12 New Member
    Irvine,CA
    I have a 2002 VFR. Everything works up til the Starter. Not sure if the starter is the actually problem. But the engine will not crank. the starter relay just clicks away. I replaced the entire harness and subharness. and yet it leads me back to the starter relay clicking away. Fuses and every connection checked. Need help asap
  2. BlackKnight12
    Irvine,CA
    the wire that goes from the starter relay to the starter does not light up when tested
  3. squirrelman
    First test battery power and starter by using pliers to jump across the 2 large terminals on the relay.........with bike in neutral, please.
    If you hear clicking it means that the relay is getting power, but may have bad contacts internally, preventing power from getting to the starter.
    It's about 100 times more likely that the starter relay is defective than the starter itself.
