5th gen no rear brake
Discussion in 'Mechanics Garage' started by windunderhawk, Feb 6, 2018.
  1. windunderhawk
    windunderhawk New Member
    Terrebonne
    Hi all, Just rebuilt front forks work great unfortunately for me rear brake inop, when i was tearing the front end off i accidentally loosened a brake hose at the junction block on the right fork leg and brake fluid leaked.
    I can understand spongy from air introduction but nothing? tried bleeding at that point of the leak no pressure there any suggestions? Thanks :Israel:
  2. fink
    fink Member
    Refill and bleed back
  3. windunderhawk
    Terrebonne
    looks like in the factory manual there is a substantial bleeding procedure shes got 25k and there is a little color in the fluid so i do believe that ill preform said procedure and see what happens,Ill bleed the clutch also.
  4. RllwJoe
    RllwJoe Insider
    I think that the cost of Speed Bleeders is well worth the investment, espcially if you plan to keep the bike for the forseeable future.
  5. windunderhawk
    Terrebonne
    OK where would u recommend I purchase them and are all the bleeders the same on the gen 5? Thanks.
  6. windunderhawk
    Terrebonne
    and whats the tread pitch?
  7. Lyle K Valentine
    Lyle K Valentine New Member
    Wire my bike. Com has a kit that looks good and some on here say good things about it. Maybe tread pitch is thread pitch.
  8. RllwJoe
    RllwJoe Insider
    Wire My Bike is the best deal I could find.
  9. windunderhawk
    Terrebonne
    Hey Kids,got speed bleeders from Wire My Bike installed them then bleed worked great GOT BRAKES. :chaingun:
    Lint and OOTV like this.
