5th gen suspension
Discussion in 'General VFR Discussions' started by jasonbrownett, Dec 17, 2017.
  1. jasonbrownett
    jasonbrownett New Member
    Wanting to replace my rear shock I started looking for replacement as original shock was pants in the first place. Can't believe how much replacements cost then I came across this on eBay. Ohlins rear shock and front springs and fork oil all set up for your weight and not stupid money, just thought I'd pass this info on in case anyone else is thinking of upgrading suspension. Mine on order Omnia racing on eBay.[​IMG]
    Sent from my Nexus 6P using Tapatalk
  2. OZ VFR
    OZ VFR Insider
    Old Toongabbie, Australia
    I might be wrong, but that looks like a 6G kit.
  3. jasonbrownett
    They all look the same in the eBay pics
  4. OOTV
    OOTV Active Member
    I think what he was referring to was the listing shows '2002>', which suggest 6 Gen (2002-2009)
  5. jasonbrownett
    No look at the arrow it means upto 2002 which is when they went from F1 to vtech model.
  6. OZ VFR
    OZ VFR Insider
    To me it reads "2002 and onwards".
    But like I said, I could be wrong.
  7. OOTV
    OOTV Active Member
    Well if it follows the way it works in math, that would be 2002 and greater. If it was meant to be up to 2001, it would be <2002...
    Anyway, hope it works out for you.
    Cheers
  8. jasonbrownett
    Do know what I think your right so have cancelled it I searched for 2000 to 2001 . Wish they would put vtech at end of description FFS still saved me some pennies. Checked on ohlins site and rear shock is an stx. Bummer.
  9. OOTV
    OOTV Active Member
    Sorry about that, always a bummer when what looks to be a good deal turns out not to be. If you're on a a budget, look into DMr www.daughertymotorsports.com, although you're across the pond, his work is great and shipping charges are usually very reasonable. Plenty of us here in the states have gone here, myself included. I had him rebuild three different shocks and two sets of forks and I am very satisfied with the results.
    Cheers
  10. jasonbrownett
    Shit happens now been told the power commander I ordered not in stock till end of Jan so cancelled that too. This is when you wish you had a more modern bike. Everything on hold now got to decide what to do wether to get a newer bike and get rid of vfr. Will sleep on it for a few days.
  11. jasonbrownett
    I've been investigating and the VTEC shock is the same but you need a 10mm spacer as it's a tad shorter so may be fine after all but I doubt fork springs would fit
