98 performance
Discussion in '5th Generation 1998-2001' started by matt1986vf500f, Sep 7, 2010.
  1. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    Howdy folks recently picked up a fifth Gen and was wanting to get the heads up on putting some pep in this things step & some suspension upgrades and how to delink the brakes
  2. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    Did you actually pay for this bike or did it mysteriously disappear from someone's garage like the old 3rd Gen that I was stupid enough to leave in your garage?
    Rollin
  3. crustyrider
    crustyrider New Member
    North Country, New York
    is it Wrestlers old bike...?
  4. Jakobi
    Jakobi New Member
    Klamath Falls, OR
    Power Commander, new muffler, air filter, and remove PAIR system and air box flapper valve. De-linking is best done by replacing the front end with something else, gets you your suspension upgrade up front, too. Easiest rear shock upgrade is to buy a 929 shock, fab a longer mount and away you go. This is all stuff on my "Things to (eventually) do to my new toy" list that I've compiled since I bought the bike in July. Also, buy the VFRness and upgraded R/R from Wire My Bike and get those installed ASAP if it hasn't already been done. After that the next common mod I've found is to replace the shift star, detent arm, and arm spring with upgraded parts from Factory Pro. I've found the stock seat to be comfortable enough but a cushy Sargent is in my future.
    -Jake
    EDIT: There's also an upgraded Fuel Pressure Regulator from Turbo City that comes highly recommended.
  5. Joey_Dude
    Joey_Dude Member
    North Georgia
    When we get together for a ride again I'll let you ride my bike so you can see how an improved suspension and going down 1 front tooth in the front sprocket feels!
  6. matt1986vf500f
    yes sir it is.
  7. matt1986vf500f
    that would be awesome joey to ride yoru with the new work you've done to it, i need to get the ol 86 out and blow the dust off of her let you ride it.
  8. matt1986vf500f
    do you have a link to the pair valve mod and flapper valve thing i've searched a few times and it just pulls up threads that has no bearing on the subject. thanks
  9. rccaulfield
    rccaulfield New Member
    why bother imo? Buy a blade for all that -no? The vfr has linked brakes and is refined but sporty, if wanted all that whyd u buy one?
  10. matt1986vf500f
    I just enjoy tinkering on things I would love to have a 2010 1000RR but just can't do it .
  11. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    I agree, linked brakes was a dumb idea in the first place. The PAIR modification is the same as other Honda models equipped with that system. There is a thin piece that looks like a minature reed valve from a 2-stroke engine. It's made so that it bends open one way, and the other way it shuts closed. You can flip this assembly over so that it does the opposite, thus blocking the unwated air flow. On my VTR I've used a sold dowel pin in place of the hollow one - that blocks it completely.
    I think I have some TBR block off plates for the VTR. Does anyone know if they fit the VFR's too?
  12. Davis5g
    Davis5g New Member
    Pittsburgh, PA
  13. Jakobi
    Jakobi New Member
    Klamath Falls, OR
    I don't. The gist of it is, you buy some block-off plates, rip all the PAIR/flapper crap out, install the PAIR block-off plates, plug any vacuum ports for the flapper valve, and call it a day.
    -Jake
  14. rccaulfield
    Fair enuf but a 98 r1 or similar go for little money these days and are beasts in stock trim, If u like tinkering maybe a bare bones restoration will keep u busy-i'm the same myself!
  15. John451
    John451 Member
  16. '97VFR750
    '97VFR750 New Member
    Atlanta
    I bet she would ride so much better if you put that White 8 spoke you still probably have laying around your trailor that you 'inherited' from someone else's bad judge of character.
    I hope you paid Ed in full, for his sake.
    Vince ('97VFR750)
  17. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    This is between me and Matt, please stay out of this.
    Rollin
  18. JamieDaugherty
    Fort Wayne, IN
    It seems to me that the VFR800 community as a whole is not really interested in more power (begs the question why Honda bothered bumping up the latest model to a 1200 in the first place). I say go for it Matt, throw in some cams or something and see if you make that sucker sing. Maybe you'll end up with the fastest normally aspirated VFR800 AND VF500F!!!
  19. j.davis
    j.davis New Member
    MODIFICATIONS TO VFR
    Pirelli Diablo front & rear tires
    gold powdercoated wheels
    right-angle tire valve stems
    K & N air filter
    M4 carbon fibre slip-on
    Dynojet Power-Commander 2
    dyno tuned by Sabin Performance Cycle
    R & R Racing aluminum exhaust hanger
    HyPerCoated exhaust system
    Penske #8981 spring/shock absorber
    Race-Tech gold valve kit
    Honda F3 fork internals & Traxxion Dynamics fork springs
    Scotts steering damper
    Nissin 14mm brake & clutch master-cylinders
    PFM cast iron front brake rotors cryogenically treated
    lightened rear brake rotor
    Galfer stainless steel brake and clutch lines
    Goodridge bleeder banjo bolts
    Carbone Lorraine SBK-3 front brake pads
    CSS Onyx bump pad
    Honda VTR1000 clip-ons
    Pro-Grip #699 gel hand-grips
    Intuitive Racing Products bar-end sliders
    Harris Performance Products adjustable rearsets
    AFAM 16-T countershaft sprocket
    AFAM 43-T rear sprocket
    RK 530 chain
    Factory Pro Tuning pro shift kit
    Recalibrator
    C-Volt digital voltmeter
    Fiamm electric air horn
    CarboTech carbon fibre front fender
    CarboTech carbon fibre tank protector
    Harris Performance Products carbon fibre chainguard/hugger
    Thurn Motorsports carbon fibre heat shield
    Thurn Motorsports rear wheel lugnut cover
    Thurn Motorsports carbon fibre front turnsignal covers
    Kyokugen alloy rear wheel lugnuts
    Magnetic oil drain plug
    2000 VFR800 mirrors
    Zero Gravity double-bubble dark smoke windscreen
    painted front fairing & tail number plates
    55/60W H4 headlight bulbs
    Dzus and Panex fairing fasteners
    miscellaneous titanium & stainless steel fasteners
    Dan Kyle preload adjusters
    Honda RC51 fairing pins
    custom-modified saddle by Sargent Saddles
    Thermo-Shield insulation applied to airbox
    Invisigard paint protection vinyl applied to front fairing
    PAIR control valve assembly removed
    fairing stickers removed
    passenger pegs & hangers removed
    rear fender shortened & license plate repositioned
    license plate light removed & tail light housing modified
  20. matt1986vf500f
    well damn i dont know where to start lol
