Bike for Sale Another abandoned project - 86 RWB 700
Discussion in 'Classifieds' started by eyhonda, Mar 10, 2018.
  1. eyhonda
    eyhonda New Member
    Detroit, MI
    I've decided this project is too much work for me at this time as I'm preparing to thin the projects for moving out of state. In it's place I will be getting a ready to rock-n-roll 5th gen VFR800. I had about 90% of the parts I needed up to this point. It all must go!!
    The big hitters to list for now:
    1. tank. clean in and out. 1 shallow quarter size ding on left and 6" dent on right. Nice paint! $225.
    2. upper cowl/fairing. very clean! no cracks or damage to mounting points! Some surface scratches and a shallow 2" dent on the right. Nice paint! $SOLD.
    3. right side panel. NOS!! nothing else to say. $250.
    4. left panel. I have 2 panels. One is rough with the small piece under kickstand broken off. $50. The other is whole with surface scratches but no repair or cracks. Good for repaint. $100.
    5. carbs. cleaned and tested before pulled. Includes brand new OEM boots ($50) for your installation pleasure! $250.
    6. Yoshimura slip-on. Some corrosion, easy to clean up. $175.
    7. seat. Looks to be recovered in blue. $75.
    Flickr link to album: https://www.flickr.com/photos/eyuzon/albums/72157666576572178
    I'll post more as I take it apart and take pics.
    I've started prepping the bike to accept F2 forks/wheels and F3 rear wheel. So, the triple clamp is already modified and the rear wheel has the correct spacers. The only thing missing from the conversion is the rear brake caliper mount and torque arm mod. I'll list those parts next.
    Shipping to con US to be added per zip code.
    Eric
    North of Detroit.
  2. 3dcycle
    3dcycle Insider
    st johnsbury vermont
    I need the upper cowl (headlight fairing) what ever you want to call it. how much for shipping to 05838? also how does the seat feel? good foam you think> wouldn't mind having that.
    any chance you have a good tail section kicking around?
  3. eyhonda
    eyhonda New Member
    Detroit, MI
    Upper cowl sold. Thanks to 3dcycle! No tail section though.
  4. eyhonda
    eyhonda New Member
    Detroit, MI
    NOS rt side panel and seat cowl sold.
  5. 3dcycle
    3dcycle Insider
    got the upper cowl. thanks a bunch, looks good.
  6. eyhonda
    eyhonda New Member
    Detroit, MI
    You're welcome! Glad you're happy!
    Also, the Yosh slip-on just sold.
  7. eyhonda
    eyhonda New Member
    Detroit, MI
    I sold the carbs and right switch. Still have lots of parts left!!
    Surprised I still haven't sold the tank!
    1. left panel. I have 2 panels. One is rough with the small piece under kickstand broken off. $50.
    The other is whole with surface scratches but no repair or cracks. Good for repaint. $100. The good panel has no broken pieces or rash!
    2. radiator and all hoses and tank. $75
    3. speedo and tach, $50 each. 20k miles
    4. headlight, $25
    5. left switch, $25
    6. left footpeg assembly, $25
    7. right footpeg assembly, $25
    8. CDi, $75.
    9. seat. Looks to be recovered in blue. $75.
    10. windshield, $50. Normal wear.
    11. fusebox, $25
    12. taillight, $20. No broken tabs.
    13. airbox, with good filter. $25.
    14. mid panels. good paint, decals. one has a broken stud. $60 for pair.
    Flickr link is updated with more pics.
  8. eyhonda
    eyhonda New Member
    Detroit, MI
    Updated list:
    1. left panel. It has surface scratches but no repair or cracks. Good for repaint. $80. No broken pieces or rash!
    2. headers. $40 for set of 4
    3. tach, $25. 20k miles
    4. headlight, $20. some broken tabs
    5. left switch, $15
    6. left footpeg assembly, $20
    7. right footpeg assembly, $20
    8. CDi, $50.
    9. seat. Looks to be recovered in blue. $60
    10. windshield, $40. Normal wear.
    11. airbox, with good filter. $25.
    12. harness, $25
    13. rear shock, $25
    14. clutch master, lever, lines, slave complete assembly. $50
    15. radiator fan, $15
    16. radiator overflow tank, $15.
    17. F2 forks, triples and rear wheel. see separate post.
    Shipping extra from MI.
    Eric
