Balancing a Tire
Discussion in 'Mechanics Garage' started by red0513, Dec 20, 2009.
  1. red0513
    red0513 New Member
    Myrtle Beach SC
    I have searched the forms and the net and I see that every one and thing talks about balancing your tire. This said, I go to my stealership yesterday, (which second location is shutting down because of shitty service) to pick up my tires. They had beat the internet price that I gave them. I ask about getting them mounted and balanced and they said it would be 104 for both and that they could not balance the read tire. He then said that he could line up the dots and that 99% percent of the time this was fine. My question is, is this really ok? I would think this would kill the life and feel of the tire, but when asked he assured me it was fine and that they do it all the time. Any insight would be great and I will supply beer if your ever in the area :thumbsup:
  2. bitterpil
    bitterpil Active Member
    Northern Virginia
    An out of balance tire will do what you think. The dots he is referring to mark what is called runout and it is matched with the heavy part of the wheel typically the valve. Issue is that sometimes that is not the exact point of the heavy part of the wheel. For instance, the heavy part of my wheel is about 2" from the valve.
    In doing my research I have read many things from many people. Some people never balance. Not a good practice IMO. Some tire brands need more balancing than others. Best thing is to balance the tires. I think your safety and well being are worth it.
    I mount and balance my own. You can get a balance stand from Harbor freight and they have a VFR adapter for about $65. You buy a pack of stickon weights from Motorcycle superstore for $12 (enough weights for several tire changes). Balancing your tires on a stand can give you better results than a spin balance machine. Mostly, because you are taking your time and be more exacting.
    I have posted this information on VFRW before but here. Watch these. They will give you some insight.
    YouTube - SCUDMAN How to remove a motorcycle tire
    YouTube - SCUDMAN How to install a motorcycle tire
    YouTube - SCUDMAN Balancing
    YouTube - Balancing a motorcycle tire
    YouTube - Mounting a Motorcycle Tire
    YouTube - Change a motorcycle tyre by hand.
    Use Windex instead of furniture polish to lube the tire.
    Good luck. I hope you get the info you are looking for.
  3. reg71
  4. monk69
    monk69 New Member
    Danville,Va.
    What ever tools you get, is going to save you money(usually 2 set's ; To 4 sets), with the cost of having it done for you. Not only money, but who's going to take the time to double check the work and to be careful enough not to scratch(reason for non scratch tools$$$)the wheel. These are close to the cheapest.... But will take some more money to mod to not scratch, I have the balancer here, but am thinking of going with the No-MarĀ® set.
    http://www.nomar-secure.com/category_s/1.htm
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42927
    - Harbor Freight Tools - Quality Tools at the Lowest Prices
  5. red0513
    red0513 New Member
    Myrtle Beach SC
    Thanks for all of the help guys. Since I live in an apartment and don't have a garage to keep tools in I am out of luck for doing it myself. Lucky for me I found a person who I ride with who used to race and mounts his own tires. He has the tools and is going to help me out. Thanks for all of the replies and sorry it took me so long to get back I had some family issues come up.
  6. bitterpil
    Northern Virginia
    Glad it is working out for you.
  7. punisher12b
    punisher12b New Member
    Montgomery County MD
    we mount and balance our own as well.. we have a NO MAR tire changer and balancer set..
  8. punisher12b
    ALSO PJ1 made a liquid balancer.. that i used.. no weights.. and it works WELL...
  9. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    I'm runnin Dyna Beads in both my tires. Seems to work great and supposedly you can recover them and re-use them in your next set also. Just my two cents.
  10. volks6000
    volks6000 New Member
    Jacksonville , Florida
    that's the way I went (Harbor freight) saved a butt load of money, plus you know it's done Right.:biggrin:
  11. Deadsmiley
    Deadsmiley Insider
    White House, TN
    I use Dyna Beads on both the CBR and the VFR. No issues here. :thumbsup:
  12. Maggot
    Maggot Member
    Park Ridge, IL
    I have balanced tires by putting the axel bolt through the rim and resting the bolt on two saw horses sitting close together. I'm sure this is not the most accurate but way better than no balance at all! You can also check how true the rim is this way.
  13. dizzy
    dizzy New Member
    MN
    Both wheels should be balanced...this is the common wisdom. That being said, it is FAR more crucial on the front the the rear. You likely won't notice an out of balance rear, that's not to say it wouldn't adversely effect tire wear. If the the front is out of balance, it's evidenced by a wheel bounce usually within a certain speed range...very irritating.
    When I do wheels, I like to mark the heavy spot on the rim to match the mark on the tire (if it has one, sometimes they don't), not because it's an adequate balance job, but because it saves on weights (less unsprung weight always a plus). Sometimes Honda does this at the factory in the form of a painted yellow dot (more weights = more cost).
    I use a K&L wheelstand with knife edge bearings to balance wheels and I think it does an excellent job...better than a spin balancer. This is also how I've observed the factory tire pros balance at professional races. I don't care for the dyna beads and I know of at least one individual who claims they made his bike handle like 'pooh' until they were removed. And the liquid balancers?...all I can say is 'yuck'!!
    That your dealer can't balance a rear VFR wheel does not bode well. It's just assumed tires are balanced with a professional job...period. There's a whole array of VFR wheel adapters that work with any tire balancing method...or they could have one made. I use a round bearing driver with a hole in the middle that's actually BRP special tool.
  14. rcompton
    rcompton New Member
    Tulsa, Oklahoma
    Just found your link for the balancer and ordered it. Thanks for the info. I used to live in Santa Maria, now I live in Ok, I would love to ride my vfr out 166 to 33 and back up the coast. Anyway thanks again.
  15. reg71
    Well come on out next year for R3-2012 and you can ride some of those roads. There will be riders from Nevada and Arizona thatbyou can join in with for the ride I'm sure.
  16. Keager
    Keager Well-Known Member
    If your stealership can't balance, is there another shop around that can? I know of a couple around my neck of the woods that do. But, that is a long way from SC.
  17. treasurediver69
    treasurediver69 New Member
    South Central Mass
    Static and Dynamic Balacing?
    I'm new here and have read as much as I can about mounting my own tires and it seems doable for my intermediate mechanical skills. The question I have about balancing is how do you do the Dynamic portion of a wheel balance? All I see here is the Static balance or do motorcycle wheels even need a Dynamic balance.
    Tire balance - Wikipedia, the free encyclopedia
    Thank you all for your insight to tires and balancing. I am ready to buy my first set and I'm going with the Michelin PR2's.
    JohnB
  18. donald branscom
    donald branscom New Member
    Guerneville CA
    You don't balance tires. You balance wheels. A wheel includes the tire. The tire WAS the problem. Some tires were 5lbs. heavier on one side. They make them better now. I have been working on motorcycles since I was 16. I am 62 now and still ride. I started out working in a motorcycle shop. A Honda dealership. Motorcycle wheels were never balanced. Some racers would statically balance them by putting them in a truing stand and putting solder or lead weight on them until the wheel could stop at any position and not turn. Very few people did that. Then the tire manufacturers came out with the dots painted on the tires. Next came the cast aluminum wheels. Wheel weights were stuck on and came off all the time. They tried to statically balance those but many times the stick on wheel weights would come off. Motorcycles got a lot of vibration going on up and down compared to a car wheel. That is why the weights would fly off.Matter of fact some riders said when the weights came off it ran smoother. BTW those static bubble balancers were known to give uneven results. The bubble balancer was not sitting on a level floor. The car people had a machine that could dynamically balance the wheel, but it had to fit in their machine so you had to have the adapter pieces for each brand of wheel. Usually only high end racing shops had those and it had a metal cage around it and it was very scary to see that operation. The other problem with that is they did not have the adapters for motorcycle wheels unless they were custom made. If you did dynamically balance the wheel you had to decide at WHICH SPEED you wanted it to be balanced. Just like a motorcycle engine , motorcycle wheels are not balanced at every speed. A calculation, (calculus) is made as to the cruising speed/RPM and the balance is calculated for that rpm and cruising speed. I have never seen a dynamic motorcycle balancing machine. There is a law of physics that says an unbalanced wheel will accelerate faster than a balanced wheel. Some of the new chopper wheels have balancing beads inside of a plastic tube wrapped around the steel wheel. I would have no worries about being on a motorcycle that has unbalnced (static), wheels.
    There are 3 kinds of wheel balancers.
    Bubble balancers are not anywhere near as accurate as either a spin or static balancer.
    A simple static/spin balancer (60-200)rpm costs about $2000.00
    Most motorcycle shops do not have that.
    But a true dynamic balancer that spins the wheel up to freeway speeds-never have seen one.
    I know of ONE car balancing dynamic balancer (full speed) because I saw it in operation in Santa Rosa Ca.
  19. donald branscom
    Guerneville CA
    You don't.
  20. donald branscom
    Guerneville CA
    Sounds like the way to go!
