CBR1000rr tail swap
Discussion in '5th Generation 1998-2001' started by I0seb, Jun 15, 2017.
  1. vegaquark
    vegaquark New Member
    Spain
    Spain
    And is that a gsf400? Love that bike so much as the vfr... Lightweight, enough power, linear response... Gimmeee!
  2. I0seb
    I0seb New Member
    Victoria
    Could be, didn't get to spend too long there but they have everything.
    Test mounted the radiator, links up nicely with the stock hoses, shouldn't be too tricky to mount it off the original oil cooler mounts, we shall see...
    sfbret likes this.
  3. vegaquark
    Spain
    Spain
    You better mount the forks withou springs to test fork travels!
  4. I0seb
    I0seb New Member
    Victoria
    Look what rolled into the garage today
    91 GSXR 750 :D
    Don't worry I'll still be working on the VFR, just more slowly.
    She's off to an exhaust shop soon for a link pipe.
    sfbret likes this.
  5. I0seb
    I0seb New Member
    Victoria
    Hey all, still alive! Just got the bike back from the exhaust shop, all linked up now :)
    TTommy and sfbret like this.
  6. I0seb
    I0seb New Member
    Victoria
    Front Fender, headlight and brackets arrived. Bar risers also arrived but haven't got them mounted yet.
    Looks like rad clearance won't be as much of an issue as I thought. Next challenge will be the new oil cooler.
    ottablue, Dav668 and sfbret like this.
  7. ottablue
    ottablue New Member
    Romania
    Great build!!! What was the height of the rider seat once all finished? Looked on the photos it was much higher than the stock and I got 29-30" inseem to deal with :) Really thinking on doing that CBR tail. I have done Gen 6 tail end on Gen 5 and it came out nice. But having only One can under seat saves some weight and bet that aluminum subframe is light compared to steel sub of Gen 6 VFR. Thanks.
  8. I0seb
    I0seb New Member
    Victoria
    Seat height was about the same as stock 5th gen but it's much skinnier so personally, I found it easier to flat foot.
    And yeah, heeaps lighter
  9. ottablue
    ottablue New Member
    Romania
    Did you have to do some custom connection to the exhaust pipe to the colle tor pipe or it lined up properly?
    Sent from my SM-G935F using Tapatalk
  10. I0seb
    I0seb New Member
    Victoria
    Yeah I had a custom link pipe made up, cost me about $150 so not too bad.
    Don't use it anymore though so it's yours if you decide to do the tail swap.
  11. ottablue
    ottablue New Member
    Romania
    Do you have the whole tail for sale? :)
  12. I0seb
    I0seb New Member
    Victoria
    Afraid not, shouldn't be too hard to follow along from here though ;)
  13. ottablue
    ottablue New Member
    Romania
    How do you find single front radiator vs stock side 2 radiators temperature differences? Which ones keep bike cooler? Thanks.
  14. I0seb
    I0seb New Member
    Victoria
    Temps while moving are the exact same, while stationary the single radiator setup gets pretty hot as it doesn't have a fan. I suspect if it did they would perform similarly while stationary as well.
  15. ottablue
    ottablue New Member
    Romania
    You did not put fan because you decided not to or was it a fit issue?
  16. I0seb
    I0seb New Member
    Victoria
    Fit issue due to the short CBR forks, would probably be able to fit a fan if you had stock front end geometry
  17. ottablue
    ottablue New Member
    Romania
    Hey Seb,
    Wanted to thank you for inspiring me to take on similar project to yours. Hope all is well, keep up great work you do and inspiring others. [​IMG][​IMG][​IMG]
    Sent from my SM-N950F using Tapatalk
    OnlyVfr likes this.
  18. I0seb
    I0seb New Member
    Victoria
    Thanks for the kind words Otta and great job on the bike, she looks fantastic!
    I've been busy with other VFR projects, been meaning to make a post here to document the work for others interested, I've done a proper front mount radiator conversion, new tail section and explored other fork swap options :D
    Got my eye on a cheap VFR1200 engine now, no idea what I'll do with it though :p
  19. ottablue
    ottablue New Member
    Romania
    Thank you for posting it all up here in the forum, really helps others to know what even is possible and what fits parts wise. Liked your radiator post got me really thinking taking on the project nice brackets too. As for VFR1200 engine not sure how much difference in size compared to 800cc engine but why not swap 800 out for 1200 I bet you can figure that one out over cup of coffee or whaetever else you prefer :bruce2:
  20. I0seb
    I0seb New Member
    Victoria
    Always happy to help, like everyone here I love Honda's V4 platform and I'm happy to share what I've discovered while working on it. I should probably write up a database of front fork swap options that I've discovered, having done R1, CBR1000 and now CBR900 RSU setups.
    As for the 1200 engine I've got a couple of ideas. Sadly the frame design of a 1200 is completely different to an 800 so a swap simply isn't possible but I think it would make a very nice swap into a small, light car ;)
