Electrical issues
Discussion in 'Mechanics Garage' started by vfr800 Interceptor junky, Apr 23, 2018.
  1. vfr800 Interceptor junky
    vfr800 Interceptor junky New Member
    Hello everyone I am having some electrical issues with my 98 Honda vfr800 Interceptor everytime I go to put a fuse in the fuse center with the relays connected it pops the fuse in the fuse pump circuit and I have checked all of the wiring harness and there is no exposed wiring is it common for the fuel pump relay and engine cut relay to go bad all because of the RR going bad?
  2. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    Is it blowing with the key off or as soon as you turn the key? You've recently replaced the RR?
  3. vfr800 Interceptor junky
    As soon as I turn the key
  4. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    That's a dead short in the fuel pump circuit. Either a hot wire is grounded or the pump is shot.
    34468 Randy likes this.
  5. vfr800 Interceptor junky
    The fuel pump is not shot it is brand new and had manually tested and It turned on
  6. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    Then you have a dead short.
  7. vfr800 Interceptor junky
    And it makes no sense why it has a dead short because I checked the wiring and it wasn't exposed whatsoever.
  8. 34468 Randy
    I am no mechanic for sure, but am an electrician. If there is a small crack or break in the insulation on a wire, it can arc and cause a dead short. How you are going to determine if this is the case or not, I can't help you with. But your symptoms are consistant with a dead short. Fuses don't blow for no reason.
  9. TOE CUTTER
    Does the fuse fail with the pump disconnected?
  10. vfr800 Interceptor junky
    No it doesn't it only happens when I connect the fuel pump relay and it blows the fuse out
  11. TOE CUTTER
    Have you altered the wiring to the fuel pump relay at all?
  12. vfr800 Interceptor junky
  13. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    Could be an internally shorted relay, replace it. If the issue is still there it has to be a shorted wire.
  14. TOE CUTTER
    And by fuel pump relay we are talking aboot a relay with a four wire connector with a brown black wire, 2 black white wires, and a brown wire. Correct?
  15. vfr800 Interceptor junky
    That is right except one of them is a red wire going into it and that's a solid wire
  16. TOE CUTTER
    Red or is it red orange?
  17. vfr800 Interceptor junky
  18. TOE CUTTER
    Not helpful from here, the engine stop relay has a connector with four wires,
    red/orange
    black
    black/white
    and black pink
    is this what your looking at?
    It will change things if it is.
  19. vfr800 Interceptor junky
    Are you talking about this one?
  20. vfr800 Interceptor junky
