Engine cover restoration
Discussion in '1st & 2nd Generation 1983-1989' started by Old86-VFR750, Aug 4, 2017.
  1. Old86-VFR750
    Old86-VFR750 New Member
    Near Toronto
    Finally found a match for the 1986 vfr750 engine covers.
    Picked them up from the powdercoater this week.
    PTB-6794 "Bronze Texture," powdercoat from prizmatic powders
    It's a good match. I found that Honda used at least 3 different shades over the production run, so this matches the one set of spare covers I had. Another set I have with the original paint is a little more pink. I like this one best.
    Sent from my iPad using Tapatalk
    Guaire, A.M and Samuel like this.
  2. derstuka
    San Diego, CA
    Wow! They look great!
    Isn't this a "winter" project though?
  3. Old86-VFR750
    Near Toronto
    Lol. Thanks. Normally but these are spare covers from eBay
  4. TOE CUTTER
    That is the first true solution for that problem, thumbs up my friend.
  5. Old86-VFR750
    Near Toronto
    I should add that if there is anyone in Toronto area that needs this done... contact Len at Edge Coatings in Newmarket.
  6. OZ VFR
    OZ VFR Insider
    Old Toongabbie, Australia
    A fantastic finish, well done.
  7. Old86-VFR750
    Near Toronto
    Installed the covers on the bike today. The side covers were pretty straightforward, kind of a pain removing 30 year old gaskets with a razor blade. The front rocker panel was easier then the rear. Hint, remove all side wires and coils from the back first. For the front, tilt rad forward, and remove fan.[​IMG][​IMG]
  8. Samuel
    Samuel New Member
    Los Angeles County
    Nice! So Clean too!
  9. Old86-VFR750
    Near Toronto
    Thanks, I stripped it down to the frame last winter and cleaned, restored or replaced each part.
  10. Captain750f
    Captain750f New Member
    Medina, OH
    Sure hope mine looks like that one day. Nice work.
