Finding wire for a high-beam trigger (aux lights)
Discussion in '8th Generation 2014-Present' started by headshrink, May 29, 2018.
  1. headshrink
    headshrink New Member
    Folsom, CA
    I need to figure out where to tap in for a high-beam trigger (to modulate controller for aux lights). I don't know if LED headlights make this any more complicated then my other bikes. Does anyone have any ideas for this?
  2. Terry Smith
    New Zealand
    There's a wiring diagram in the service manual; I'd suggest either the blue/black wire from the headlight relay to the LED driver, or the solid blue wire leading from the lefthand switch block to the headlight relay, both are high beam specific. The former being fed from the relay presumably has higher current capacity to feed other things.
    Diving Pete likes this.
  3. amoreira88
    amoreira88 New Member
    Phila, PA.
  4. headshrink
    Folsom, CA
    Awesome, thanks!
