First Ride on my new 2015 VFR Deluxe
Discussion in '8th Generation 2014-Present' started by dlp, May 3, 2018.
  1. dlp
    dlp New Member
    Did 150 mile lunch ride with some friends.. ODO was at 1 when I picked the bike up yesterday at dealer... put a set of the motopumps .6" risers on last night, lowered the back of the seat (left front risers in) - (I'm 5'6", 30" inseam 160 lbs) and the seating position feels great. Some observations: We took mostly back roads, so plenty of opportunity to vary engine RPM's, speed and wear in new tires.. Now, going over bumps and uneven roads reminds me of my 1996 Ducati 900 SS, not exactly BMW RT like.... ride feels a bit stiff, but imagine will loosen up some, throttle is touchy in the near off position, esp in 1st as you'd imagine.. coolant temps got as high as 209° F in stopped traffic, would go back down immediately at speed. bike handles well, brakes are OK, didn't seem to grab, nor did the ABS come on....bike is heavy ( like my '99 RT was) when I forgot and parked facing down a sloped spot and had to walk bike out of space.... All in all, a good ride with friends, and isn't that what it's all about?
    Quibble likes this.
  2. Diving Pete
    Diving Pete Insider
    But did you enjoy it on this bike?
    Bubba Utah likes this.
  3. Allyance
    Allyance Insider
    East Bay, California
    I've done that, once!
  4. dlp
    dlp New Member
    Yes sir I did... thanks for asking, I should have said that... I'm still smiling...
  5. Bubba Utah
    Bubba Utah Insider
    Utah
    Don't worry about the temp. the bike runs hot. Mine stays between 189-220 mostly around your posted temp.
  6. Allyance
    Allyance Insider
    Runs hot in traffic, but never a problem. On the other end, it needs to warm up a while before starting out. VTEC won’t kick in till about 147 degrees. You can start sooner, but won’t run smoothly till it’s warm. Guess it’s the fine tuning!
  7. Tiutis
    Tiutis New Member
    Lakewood, CO
    Check the preload to loosen the suspension. You're about my weight and I found that 4 bars showing on the rear preload is what works best when I ride without bags. I forget about what I have on front, but I think it's bearly half or only one turn from all the way soft.
    dlp likes this.
  8. GatorGreg
    GatorGreg Honda Fanboy/LitiGator
    Orlando
  9. dlp
    dlp New Member
    Thank you, I've made those adjustments and will try them out, IF it ever stops raining here..
  10. Bubba Utah
    Bubba Utah Insider
    Utah
    You guys or gals with the deluxe always talking about adjustment! I personally like the bobble head effect of the F. ;-) I bobble here and there and get a massage every here and there! ;-)
