So i am trying to find the relay to check if it went bad. I installed led blinkers and it flashed 3 times and then nothing cant get brake light to work either. Any help would be great!
I’m no expert, but don’t you need special relay for LED blinkers? I think the normal bulb has two wires inside for front blinkers. Sent from my iPhone using Tapatalk
Yes it does i just cant seem to locate the relay to replace it. Update i found the relay. Luckly i had only blown a fuse. Got the blinkers wired in and they blink fine except when the lights are on so. Now tk figure that one out
