Front sprocket play
Discussion in '8th Generation 2014-Present' started by BalticVFR, Jul 5, 2018.
  1. BalticVFR
    BalticVFR New Member
    Reserved
    Hello
    After replacement of sprockets and chain, i noticed, that front sprocket has not beent firlmy pressed, even when i tighten all up. It has small play on axis. Is that normal or should i use new washer?
    Kind regards
  2. FJ12rydertoo
    FJ12rydertoo New Member
    Platte City, MO
    A little lateral play is fine, any rotational play is not. Also use some anti seize to lube the splines before
    you install the sprocket.
  3. BalticVFR
    Reserved
    Thanks for info! Had some doubts.
