Greetings from Poland
Discussion in 'Introductions' started by Hirad, Sep 12, 2017.
  1. Hirad
    Hirad New Member
    Poland
    Hello!
    My name is Bartosz, and as you can see i'm from Poland. Now i'm 28 years old.
    Officially i work as Project Manager in IT Company (Test and Deployment automation)
    Privately im huge fan of Fantasy books, TV Shows, Bikes (of course!) and Mountains.
    Now i'm riding on GSF 600 N (Bandit), but tomorrow i will inspect (potentially) new bike - Honda VFR from 2008 year.
    On this forum i'm looking for more information about this bike.
    Soooo, that's it for now!
    If you guys will have any questions, please ask them ;)
    Cheers!
  2. lone_wolf
    lone_wolf New Member
    Welcome Bartosz! Let us know what happens when you seen the '08 tomorrow.
  3. skimad4x4
    France
    French Alps & London
    Hi Batosz - welcome to the MadHouse
    Sorry for the delay in spotting your post - So how did the viewing go?
    You asked for thoughts on the 2008 VFR. Inherently all 6th Gen VFRs are a fair bit heavier than your Bandit especially if it has full luggage fitted. So if you decided to buy the VFR, take care until you get used to the extra weight - or they can end up on their side.
    Mechanically - with proper servicing these bikes can reliably cover immense distances - making them a great sport touring bike. The V4 engine is very strong and sounds glorious as the extra valves kick in and the bike makes a lunge at the horizon.
    The primary weakness on 6th Gens is the charging system - which can largely be solved by replacing the stock RR with a decent Shindengen RR and fitting a voltmeter to keep an eye on system volts as you ride. The VTEC valve check is expensive and is probably required excessively frequently - unless you intend to use the bike as a regular track day mule. Consequently many Vtec owners have chosen to skip every other Vtec valve check and usually find that all the Valves are in spec when it was eventually checked.
    SkiMad
  4. Hirad
    Hirad New Member
    Poland
    Hello again guys!
    Viewing was kinda amazing ;) Friend of mine - mechanic, visited me in Warsaw and helped me witch it.
    After and hour, and twe rides he said, that this VFR is in amazing shape.
    On stock:
    * Set of 3 motorcycle trunk (Givi + Kappa)
    * Custom seat
    * Custom handlebars
    * Heated grips
    * Phone mount
    * Charger
    * Custom made exhaust
    * New tires (dot: end of 2016)
    I plan to install custom windshield, but it will happen in next year.
    Pics of my new bike ;)
    Samuel and skimad4x4 like this.
  5. Samuel
    Samuel Member
    Los Angeles County
    Looking Good Bart! :)
  6. duccmann
  7. squirrelman
    shitcan the phone mount and charger; no distractions permitted !!~
