Helibars on backwards
Discussion in '7th Generation 2010-Present' started by donutninja, Jun 7, 2014.
  1. donutninja
    donutninja New Member
    So I took my bike to the shop to have them install the new Helibars I bought, and the tech told me that the holes were missing on the right bar, and he'd have to drill them to get everything to fit right. I mentioned that there were holes on the other bar, but he seemed to think that both bars needed holes. After carefully drilling holes, installing the right bar, then trying to install the left bar, he came to the conclusion that he'd been putting the bars on backwards the whole time.
    He switched them out, and the install went pretty smoothly after that. So now I have a few extra holes on one helibar, do you think that will affect the integrity of the handlebar at all? Oops.
  2. Badbilly
    It would affect taking any work back to that shop. Was this a Harley shop by chance? I was going to suggest some T-shirts that say RTFM but if the shop is a Harley shop it will do no good.
    I hope this helps.
  3. sunofwolf
    sunofwolf Active Member
    :spider::tsk:You will find out when they fail if you survive the crash? Pics might help us determine when they fail. ask Bad Billy for info!
  4. MrSleep
    MrSleep Member
    Verdigris, Oklahoma
    Send an email to HeliBars explaining what happened with pictures. Ask them if theyfeel they are safe or need to be replaced. If and When they can't guarantee thier safety and recomend replacing them then let your mechanic know and show him the letter from HeliBar. If he doesn't replace them at his cost then you have a case for small claims court.
  5. Motor
    Motor New Member
    You could put some J.B Weld in the hole if it bothers you. Or have a weld shop fill the hole. The shop should still compensate you in some way.Maybe give you a break on the install,since they botched the install
  6. sunofwolf
    this is a common mistake on Heli bars for some reason
  7. FJ12rydertoo
    FJ12rydertoo Well-Known Member
    Platte City, MO
    Yeah, I started to put mine on backwards but could see that it just wasn't right. For some reason they just look right if they're on backwards. Go figure.
  8. Badbilly
    I bet some chewing gum would plug holes in those Helibars too. I'd get the gray kind rather than pink bubblegum for a better color match. For those confused with right from left the gum should be chewed some first IMO.
  9. VFR joe
    VFR joe New Member
    this is best answer.
    better than the chewing gum answer. but it was close...
  10. VFR777
    VFR777 New Member
    Kansas
    Dude drilled the hole, his mistake. He should replace it. End of story in my books.
  11. tinkerinWstuff
  12. Pliskin
    Pliskin Active Member
    Morris County, New Jersey
    Ditto.
    I don't care what the part is. If some dude went and drilled holes in my brand new part because he didn't know WTF he was doing, he'll be paying for new parts, thank you very much.
  13. Y2Kviffer
    Y2Kviffer Active Member
    RALEIGH, NC
    It's been many moons ago, but i think mine were marked left and right. If you want a little more height you can slide them up the tube so the top is flush :wink:
  14. Gator
    Gator Insider
    He should buy you a new bar. I would not worry about the integrity of the bar but the integrity of the mechanic if he does not do right. I put on ConvertiBars and it was very simple. Never have experience with heli.
  15. donutninja
    Thanks for the input, I'm chewing gum right now just in case. I e-mailed Heli a few days ago, still awaiting their response. The shop knocked $50 off the installation cost the day of, we'll see how amicable they'll be to buying a new bar for me. I'll wait till I get something in writing from Heli either way, that'll make my case easier.
  16. Badbilly
    Heli makes a great product. The mach 1 91 fell over and one bar was bent. Hoping that the bent bar could be straightened , I called them. Bottom line was no dice and they no longer were tooled up to make a set for the 91.
    The hassle was wading through the chicas who answer the phones whose favorite word is no. I finally got hold of the boss and he made me up a set to fit the bike at no extra charge.
    What we don't know is how big is this hole and do you prefer spearmint or doublemint.. as in the fine example above.
  17. VFR777
    VFR777 New Member
    Kansas
    Dude you already have a case the dumb ass drilled a hole in your new Heli Bars what a dumb fuck!!
  18. dynajohn
    dynajohn Member
    KY
    Geez billy, there you go again with the Harley bashing. If donutninja had a HD shop install Heli bars on his VFR the mechanic would have made the extra holes with a punch & hammer not one of those sissy drill bits.
