Help!!! 93 vfr 750 stator
Discussion in '3rd & 4th Generation 1990-1997' started by Stevehoff, May 19, 2017.
  1. Stevehoff
    Stevehoff New Member
    Indiana
    How to rebuild the stator
    Is it possible?
  2. slovcan
    slovcan New Member
    Annapolis Valley, NS, Canada - IBA #63720
  3. Stevehoff
    Indiana
    When I start the bike it runs until I let go of the start button then it dies. Anyone know what's wrong or how I can fix it
  4. squirrelman
    low or bad fuel, gummed-up carbs ? read the FSM. you could even read it on your shmartfone. :biggrin-new:
    if the engine only turns over using the starter, it's not running at all. :eek-new:
    checking for spark would be a good first step.:eagerness:
  5. mastergregor
    mastergregor New Member
    Arlington Heights, IL
    Has the bike been sitting for a while? If so, gummed up carbs and jets could be a problem. I guess it would be good if you share a bit of history on the bike.
