The bike I bought this year has some aftermarket aluminum grips. I was doing a bit of cleaning and I saw that the push-pull ring with internal teeth was split between the cable ends. The throttle still works without problem, but I just want to fix it. Does anyone know where I can buy just the ring (for now)? Or should I just replace the whole grip? If I replace the whole grip, do I need to get a throttle tube? This is my first grip replacement... I have a 2001 5th gen with the stock risers.
