Ignition coils
Discussion in '3rd & 4th Generation 1990-1997' started by Rckslick333, Jun 21, 2018.
  1. Rckslick333
    Rckslick333 New Member
    iso ignition coil wiring diagram. I’ve done some searching in the forums and can’t track it down. I have a 1990 VFR 750.
    Thanks guys/gals!
  2. Terry Smith
    How's that?
    Rckslick333 likes this.
  3. Rckslick333
    You're fantastic!!! Thank you so much!
  4. Terry Smith
    Happy to help. I have the manual on .pdf if you need it, I just found it on the net.
  5. Rckslick333
    I saw a post on here, but can’t find it now. I’ve got a 1990 vfr750 and in the process of going naked.
    Is it possible to replace the stock coils with coil on plugs? The post I saw mentioned doing this with the coil packs from a gsxr750 and connectors from a CBR1000.
  6. squirrelman
    Sure, i f you're carrying around alot of excess cash, but not all are, so.........................
    with some simple wiring mods a 8th grader could do, you can use some real creativity to hide the stock coils in a remote location. just need longer wires and some plugs you can find anywhere.
    where you hiding the coolant bottle ?
    check for ideas with search, as some nice VFR streetfighter mods have appeared here but fewer than half look good to me. o_O
  7. OZ VFR
    OZ VFR Member
    Old Toongabbie, Australia
    Not sure if thet fit the 750, but this is how they fit the 5G.
    2006 GSXR750 coils with CBR1000RR wiring (which has the same colour coding as the 5G).
    Much lighter and much cleaner then the old 1950's design coil packs.
    Lint likes this.
  8. Lint
    Lint Member
    Simi Valley, Ca.
    Always good to have a fresh spark too!
