Mild Detergent
Discussion in 'Gear & Accessories' started by Lgn001, Jan 18, 2008.
  1. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    Anybody in VFR land know what the heck "mild detergent" is? :redface: Does that tend to be on the side of dishwashing soap, laundry soap, or ???? My Cortech jacket & other miscellaneous M/C stuff needs to be "hand washed with mild detergent", but I am clueless as to what that means.
    I have deduced that kerosene, gasoline, and paint thinner don't qualify...:confused:
  2. derstuka
    San Diego, CA
    Seems like any normal detergent like Tide or Cheer should fit the bill.
  3. jasonsmith
    jasonsmith Member
    Vancouver, BC
    Watch out for laundry soap. It is way more powerful than you think. When our super expensive soap to remove the exhaust build up on the helicopters wasn't around we would use laundry soap. It worked really well :eek:
    But I think it should be ok... Most stuff says to use mild and most people just use what they have.
  4. GenLightening
    GenLightening New Member
    Minden, NV
    Use a liquid. The powders tend to "scratch" things a bit and can take the color off leather. Use less than you think you need to start with and then use more if needed.
  5. VT Viffer
    VT Viffer New Member
    South Carolina
    Mild detergent=use less.
    So if you use a cup to do a load of laundry, use a thinned out (with water) 1/3 of a cup of detergent.
    I would also recommend NOT using dish soap, as it is WAYYY stronger (degreasing wise) than laundry soap.
  6. Lgn001
    Lgn001 Member
    Liquid laundry detergent, highly diluted, it is. I washed the jacket once (year or two ago?), and read something afterwards (probably in a cycle mag) about the waterproofing being affected by strong detergents.
    I haven't gotten around to it since, and it is starting to look more like fire-fighting protection than a riding jacket.
    Thanks, All!
  7. rngdng
    rngdng New Member
    Goose Creek, SC
    I'd use regular laundry detergent as mentioned above. If you're concerned about waterproofing, get a can of Scotch-Gard. I don't really see how it could hurt the waterproofing anyway, since Cortech is waterproof by virtue of it's microscopic pores.
    Lane
  8. squirrelman
    REAL MEN don't know much about dish soap or detergent... and wouldn't be inclined to use it anyway because soap weakens the skin, a well-know fact .....or are we all turning into Martha flipping Stewart??
    Just wash it with your pantyhose, Martha!!:cheer2:
    If you wear a garbage bag over those fancy duds they won't need washing!
  9. rngdng
    rngdng New Member
    Goose Creek, SC
    That's an awfully macho response from someone who doesn't ride a Harley! Perhaps you have latent tendancies????
    :rolleyes: :rolleyes: :rolleyes:
    Lane
  10. Lgn001
    Lgn001 Member
    The garbage bags made too much flapping noise, even with the duct tape.
  11. squirrelman
    loud flaps save lives!!
  12. Lgn001
    Lgn001 Member
    Now that you mention it, I did notice that people went out of their way to avoid me, whether I was riding or not.
  13. squirrelman
    well, people don't avoid me untill after i've removed my full-face helmet...then they scatter, especially girls!
  14. eddievalleytrailer
    eddievalleytrailer Member
    Jonesborough, TN
    Woolite is made for hand washing. It is right beside laundry soap in the grocery store. If that doesn't work, try a little battery acid.
    (the battery acid is a joke, don't use it unless you want some rather large holes in your stuff)
  15. Chicken Little
    Chicken Little New Member
    Woolite, spray the bad stuff first with Spray n' Wash.
  16. 34468 Randy
    So...How did it turn out? The gear still waterproof? I just washed a Joe Rocket textile that was very good in the rain, now it is the shits. Anyone out there with a good tried and tested waterproofing for textile suits?. At first I though Scotch guard would be a good choice but thinking this over, is it really more appropriate for causing spills to bead off? Would it stand up to routine driving at highway speeds in the rain? I got soaked coming home from work today. :rain: Maybe my belly will shrink?
    And as far as dish washing liquid goes, think about it. If it will clean greasy pots and pans, I think it would be pretty harsh on our gear. When I do get my hands greasy working on cars or what ever, I use dish washing liquid to clean the grease off my hands. It works great. And its good for the hands too Madge. Your soaking in it now.
  17. Lgn001
    Lgn001 Member
    I haven't ridden in the rain for a long, long time... in a galaxy far, far, away...
    Uuuh, where was I? Oh, yeah, heavy drizzle is about the most I have had to contend with, and no more than about half an hour. Nothing got damp underneath, for what that is worth, but I would have been surprised if it did.
  18. yoda6669
    yoda6669 New Member
    Georgetown, TX
    yodasmile Have anyone tried to blend laundry detergent with dish soap(dawn for example). Pretty potent stuff, awesome for white leathers(I use that trick to clean my white adidas).
  19. VFR-Guy2000
    VFR-Guy2000 New Member
    Holladay, Utah
    This is what I do with my Joe Rocket jacket right down to the spray n wash even. My jacket has some parts of it that are white and gets to be gray after some time, so I hose it down with the Spray n Wash, then fill the tub up with some water and Woolite. Then add one jacket to the mix, swish things around and rub with your hands only(no scrub brushes). Rinse out and repeat this again if needed, then let it air dry. I have had good luck doing it this way. It also won't damage the reflective stripps if you do it this way.
