motopump 1,25
Discussion in '8th Generation 2014-Present' started by Gianfranco, Apr 5, 2018.
  1. Gianfranco
    Gianfranco New Member
    Italy
    hello to everyone, today my mechanic must mount me the riser bar motopump from 1.25 and says that we must also raise the forks. Why on the forum it is said that it is not necessary?
  2. ALAN553
    ALAN553 New Member
    Montville,NJ
    NO WAY!...2 minute job, take bolts out, lift handles, slide riser in, new bolts...
  3. Nelix
    Nelix New Member
    Paisley
    Two steps.
    1. Change your mechanic.
    2. Fit the bar risers.
    Seriously, just do it yourself, easy job.
  4. Gianfranco
    Italy
    ok, grazie, ci proverò
  5. jcubz
    jcubz New Member
    I'll like to second all these people. I put my 1.25 on with ease, and I'm a mechanical idiot. All joking aside, you should really find a new mechanic! He or she is really trying to scam you.
  6. Vulcanator
    Vulcanator New Member
    Portland, OR
    I think the reason your mechanic probably said that is the fact the 1.25" riser will cover the whole exposed section of the fork tube that's above the upper triple clamp. When you attach your handle bar, it will only be secured by the Allen bolts supplied in the kit. I didn't feel I needed that much rise, I used the 0.6" risers which give a more "factory" look after installation. I wanted to have the bars still cover the fork tubes for a bit more security. You could lower the fork tubes, but you'll change the ride geometry.
  7. Gianfranco
    Italy
    [QUOTE = "Vulcanator, post: 582717, member: 35957"] Penso che il motivo per cui il tuo meccanico probabilmente ha detto che è il fatto che il montante da 1,25 "coprirà l'intera sezione esposta del tubo della forcella che è sopra il morsetto superiore. Attaccare la barra della maniglia, sarà assicurata solo dai bulloni Allen forniti nel kit. Non mi sentivo più necessario, ho usato i riser da 0,6 "che danno un aspetto più" factory "dopo l'installazione. Volevo che le barre coprissero ancora i tubi della forcella per un po 'più di sicurezza. Potresti abbassare i tubi della forcella, ma cambierai la geometria della corsa. [/ QUOTE]
  8. Gianfranco
    Italy
  9. Gianfranco
    Italy
    I put them plug and play, now I do a few miles to try them if I feel good I leave them like that.
  10. VFR_Mike
    VFR_Mike New Member
    SW of Chicago
    As long as you have enough slack in your cables, it's easy to do yourself.
    Lose that mechanic - he has no idea what he's doing.
