I helped my neighbor pull the wheels off his 07 Sixth gen. He's getting new tires spooned on today. He bought the bike used and doesn't have an owner's manual. I need to know the torque specs for the four rear wheel lug bolts and the brake caliper mounting bolts for the right caliper. Also, the bolts had red loctite on them. Is this correct? Also, is there a service manual online that can be downloaded? Thanks in advance.
The torque specs for rear wheel shoukd be in e owners manual. It is in my 6th gen owners manual. In my book it is in the flat tire section. The spec on mine is 80lbs. Since Honda doesnt want you to do the service on your bike it was under emergency tire chage. Not under the tire section.
The wheel nuts are 80ft/lbs and the caliper bolts are 23 ft/lbs. Here is the link to the downloads section. Just download the 2002 manual which applies to all 6th Gen bikes since they are all the same with the exception of the braking components of the ABS model. CLICKY HERE >>> http://vfrworld.com/forums/specifications/3161-downloadable-parts-catalogs-service-manuals.html Rollin
