oil and filter thread
Discussion in '8th Generation 2014-Present' started by armod, Aug 26, 2017.
  1. Gator
    Gator Insider
    While there is some truth to this there is still break in and mating time on the rings to cylinder surfaces, there is a much longer break in time for the transmission.
    XRedJar likes this.
  2. mello dude
    mello dude Member
    Probly 10years back, I went on a trip with a buddy who had a Ducati SS900. He said he just switched to a synth from Dino on the thing with a whole 450 miles on the bike. By the time we were nailing twists in West Virginia the thing was spitting oil smoke at me as I followed the thing.. bleah. He ended up filing a warranty claim (yeah rings) and got a new engine for the bike. -- This is prolly a remote case, but I will still stick with the old school of running dino for 7k to 10k mile before the synth switch for a newer bike.
  3. Gator
    Gator Insider
    I doubt that synthetic oil caused those problems. Some cars are even broken in on full synthetic. Porsche breaks in their cars with Mobil 1 Full synthetic.
    XRedJar, fink and Thumbs like this.
  4. armod
    armod New Member
    Perth, Western Australia
    The way it has been explained to me is that synthetic oil gets through openings that mineral oil can't and before the rings are properly mated it can bleed into the cylinder and be "consumed" with the fuel and air.
    New cars designed for synthetic oils are engineered to avoid your Ducati rider friend's problem.
    Similar problems come from the classic car crowd who have been engines that have been run for a long time and after switching to synthetic oil they start leaking and jump to the conclusion that the oil made the car leak and has therefore caused damage to the engine when it is just slipping through the gaps that the dino oil couldn't.
    My mechanic (Honda shop guy) says after the 1000km service a blended oil will be fine. He then recommended the HP4 which he's probably obligated to do.
    The Honda HP4 is not full synthetic but blended.
    Unfortunately there are no standards or minimums for what qualifies as blended. It could just be one tablespoon per barrel of base oil and it can be called a blend.
    I contacted Penrite and was told by their representative that their blended oils contain a minimum of 20% synthetic. I couldn't get such info about the Honda oil.
  5. Robborboy
    Robborboy New Member
    Cleveland, Tennessee
    That's not true at all. The thickness/viscosity is told in the oil weight. A 40 weight Dino is the same as a 40 weight synth. Just as thick. And can get in just as many places.
    Sent from my Galaxy S8 Active
    Thumbs likes this.
  6. Thumbs
    Thumbs Insider
    Bath(ish)
    That's why it's SAE 40
    Society of Automobile Engineers or API American Petroleum Institute
    Robborboy likes this.
  7. fink
    fink Insider
    In the vfr it should actually be 30w
  8. ALAN553
    ALAN553 New Member
    Montville,NJ
    The basic difference between sythentic and Dino is longevity. Day 1, they are the same viscosity...day 2....that’s when things start to change...
  9. XRedJar
    XRedJar New Member
    Laurel, MD
    I’d like to know if cars that come from the factory with synthetic have already been through a break in process at the factory.
    There is no harm in running Dino oil for the first few changes. Maybe I’m just old school, but I have to believe there is a benefit to running Dino oil for the first couple thousand miles to ensure things wear in properly. Cheap insurance to me.
    I will be running synthetic in mine, probably about the 3000 mile mark. Oil and break in are two largely debated topics. I guess as long as you feel confident in what you’re using, that’s all that matters.
  10. FJ12rydertoo
    FJ12rydertoo New Member
    Platte City, MO
    If I bought a new bike I'd run synthetic from the first oil change. Of course the last new bike I bought was 32 years ago. Synthetics were
    still pretty rare then, so I ran what was cheap: Castrol GTX.
  11. fink
    fink Insider
    Care to elaborate please.
  12. ALAN553
    ALAN553 New Member
    Montville,NJ
    synthetics maintain their lubrication properties longer, hence the longer service interval.....
  13. FJ12rydertoo
    Platte City, MO
    A bit of a bump.
    I did get around and change the oil and filter in the bike today. Had a heck of a time deciding on which oil to use.
    I was waffling between Mobile 1 Synthetic Motorcycle Oil, and the Castrol Synthetic Motorcycle oil. But simply
    could not bring myself to spend nearly $50 on an oil change for the bike. Shoot, the Dodge costs less than that
    and it uses 3 gallons.
    So I ended up going with Shell Rotella T-6 Synthetic. O'Reilly's had it on sale for $21.95/gallon and I had a coupon
    for $5 off. Used a Bosch filter I had on hand and I'm good for less than $25. A lot of guys use the T-6 so I figure what
    the heck.
    They don't make Castrol Syntec anymore that I used to use. I had a fair supply that I bought up when they ran a heck of a sale
    on it and I bought a ton of it. But my last oil change used up the last of it.
  14. RhINO
    RhINO New Member
    Sweden
    Stockholm
    My manual says 10w40 or 10w30 as an option.
    Skickat från min E5823 via Tapatalk
  15. RhINO
    RhINO New Member
    Sweden
    Stockholm
    Damn, hit send by mistake, it should continue, did they cache that to the 8th gen?
  16. fink
    fink Insider
    From 2014 on it reads 10W30 .
