Pair Valve Blockoff Mod
Discussion in 'VFR wiki' started by mpugh, Nov 16, 2007.
  1. mpugh
    mpugh New Member
    Discussion thread for Pair Valve Blockoff Mod. If you would like to add a comment, click the Post Reply button.
  2. Joe Nardy
    Joe Nardy New Member
    Lombard, IL
    Help locating PAIR valve '04 VFR800
    I want to do the pair blockoff mod on my '04 VFR. I'm unsure what the PAIR valve is. There are two hoses coming out of my airbox. One comes out of the right side of the airbox and goes to the rear valve cover. I'm guessing this is a crankcase breather. The other hose comes out of the left side of the airbox and goes to an assembly mounted to the airbox. There are two hoses coming out of this assembly that runs along the left and right side of the airbox and go ???. Which hose(s) do I block off?
    Thanks for any help,
    Joe
  3. derstuka
    San Diego, CA
  4. Joe Nardy
    Lombard, IL
    Jason,
    Thanks for the link. I had read through it before but it didn't go into much detail. I re-read the WIKI post and it made more sense. I used a rubber stopper to plug the fitting in the left side of the airbox and reconnected the hose. I noticed that the idle dropped a bit and that it seems to drop RPMs quicker when the throttle is shut off. I don't hear any popping I usually have (Two Brothers carbon slip-on). I'll report back a bit later after I get the oil changed and take it for a spin.
    Thanks again,
    Joe
  5. Joe Nardy
    Lombard, IL
    I took the bike for a short ride and there is definitely a noticeable difference in low RPM fueling. It is much smoother out of slow corners and easier to casually pull away from stops. I still get a bit of popping on decel but I suspect that will remain until I get a Power Commander.
    Thanks for the help,
    Joe
  6. wlink66c
    wlink66c New Member
    St. Louis, MO
    Pair valve question
    Will blocking off the PAIR valve cause any damage to the Catalytic converter?
  7. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    In theory, if I understand the PAIR valve correctly, it could accelerate the wear to the convertor because you will have a richer mixture traveling through the exhust more often. I don't think we've heared of any rampant cat failures due to doing the PAIR mod though. Just did it to mine with the PC3, I am un worried about trashing the cat, it won't cause any FI lights to come on nor should it cause any problems unless it actually becomes clogged.
  8. tinkerinWstuff
    waste of time and energy. The PAIR pumps filtered air into the exhaust. It doesn't rob power and removing does nothing to add power. I think anyone who says they notice a difference after removal is wishful thinking. I've run the 3rd gen on the dyno both ways with no change at all on the graph.
  9. wlink66c
    wlink66c New Member
    St. Louis, MO
    Thanks, I'm just trying to get rid of the annoying surging on my 2008 around 3500rpm in the lower gears 1st, 2nd or 3rd. After reading through the post here on VRFWorld it looked as if the PAIR valve block off would help with that particular issue.
  10. tinkerinWstuff
  11. havcar
    havcar New Member
    Denver CO
    +1 to Tink's comment. I also hated the off-idle surge. PCIII and a custom map cured it all, as well as the power drop from 5500-6500 rpm. Maybe not huge HP gains, but a much better running machine nonetheless. You've already got the expensive exhaust, might as well go the last mile and maximize your rides performance with a PCIII and a dyno. You could still do the whole mod before you got a map, but the only real benefit is about an 8lb drop in weight.
  12. 02 VFR Rider
    02 VFR Rider New Member
    again tink, no HP gains but the low rpm throttle response is better.
    FI runs off of the 02 sensors so the AIR from the pair valves will affect the FI
    maybe time to step up to a 6th gen to try before and after for this mod.
  13. tinkerinWstuff
    Honda Engineering wasn't smart enough to realize that?
    PC and custom fuel map gets much better reviews as it smooths things out through the whole RPM range.
  14. wlink66c
    wlink66c New Member
    St. Louis, MO
    Thanks everyone...this is a great site. Judging from your replies I'm moving ahead with the PAIR valve removal, a PC and dyno tune. Thanks again.
    BTW Tink, I found this bike on Craigslist in Aurora, CO. The seller was moving to D.C. and had to part with it. 447 miles on the ODO, BMC filter, Heli Bars, Leo Vince (alum), Zero Gravity double Bubble for $6500. Felt like a steal. I doubled the original mileage just riding her back to St. Louis. :)
  15. 02 VFR Rider
    yes they did, It is set up to lean the bike for emissions and it does affect the fuel mapping a tad.
    PC is the way to go if you have the cash for it plus the dyno tune..
    IMO there are other cheaper ways to get the same gains..
    Also show me a Honda engineer riding a 6th gen and I will show you a honda engineer with pair block off plates on it.
  16. tinkerinWstuff
    Awesome! You'll have to come back when you get her all dialed in! I'm sure you saw those mountains calling.
  17. tinkerinWstuff
    I beg to differ. The system sends oxygen into the exhaust to burn hydrocarbons. It does not lean out the mixture going through the combustion chamber. If anything, by your logic of the 02 sensors reading a lean mixture (from air allowed in by the PAIR) it would cause the combustion mixture to be rich.
    So again by your logic, blocking the plates would allow less oxygen rich air to hit the 02 sensor. The bike would read this and go, "HOLY SHIT WE ARE RUNNING RICH" and would then lean out the mixture to compensate.
    Therefor, if someone WAS to do a PAIR blockoff on a FI bike, it's even that much more important to do a PC and custom dyno tune.
    That's my take until someone can produce evidence, beyond backyard mechanic theory, to show they are smarter than Honda engineering.
    Maybe you can produce one of these Honda techs on a 6gen with blocked off plates?
  18. 02 VFR Rider
    :doh: :doh: :doh: :doh: :doh:
  19. tinkerinWstuff
    I try. Have a beer. :drinkers:
  20. vfourbear
    vfourbear New Member
    Louisville, KY - Under my tinfoil hat
    :dance:
    Hi Five
    Coming soon- a new thread asking about PAIR Valve mods, coming to a forum near you.
    :hangme:
    Its like the Rocky Movies.
