1. BluRoad
    BluRoad New Member
    Antioch, IL
    I have many parts from my 1990 VFR which I'm parting out. Will fit 90-93 VFRs. All prices plus shipping to CONUS (only).
    Joe, Antioch IL
    joe.nelson@ymail.com
    (email works better than PM)
    608-807-7829
    SOLD Fuel Tank - red from a 1990, small dent, perfect interior $60
    Fuel Tank - black from a 1992, small dent, slight surface rust on interior $50
    Ft. brake calipers, rebuilt, no pads $50 set (rt & lt)
    Rr. subframe $20
    Rr. fender $15
    Passenger peg eliminator brackets - set, shaved & smoothed $20
    Chain guard $12
    Pulse generator $35
    SOLD Forks - rebuilt $70
    Master cylinders - Ft. brake & clutch w/ red LP covers $30 each
    Coolant hoses $5
    Thermostat, housing w/ temp sender $10
    Water pump cover $5
    Small infill panel, left side (i.e., covers fuse box area, hard to find) $8
    Airbox - no snorkel $10
    Triple tree assembly - newer tapered bearings installed $25
    Stator $15
    Kickstand $15
    Rr. brake switch $5
    Speedo cable $10
    Solenoid (starter) incl. starter cable $10
    Left side handlebar switch assembly - incl. choke cable $30
    PAIR assembly w/ large hoses & brackets $10
    Rr. wheel lug nuts $10 set
  2. BluRoad
    BluRoad New Member
    Antioch, IL
    Forks = sold
    Red fuel tank = sold
  3. VFR750F3
    VFR750F3 New Member
    White Plains NY & Weeki Wachee FL
    Joe, is the rear fender unmodified? If so, consider it sold.
    kevin
  4. BluRoad
    BluRoad New Member
    Antioch, IL
    Sorry, trimmed to fit just the license plate and painted gloss black.
    Joe
