Rear shock replacement
Discussion in '5th Generation 1998-2001' started by rc24ste, May 13, 2011.
  1. rc24ste
    rc24ste New Member
    UK
    Anyone know whether a VTEC VFR800 rear shock will fit my 1998 VFR800? I'm looking for a straight bolt in job (no new brackets, fabrication, hacksaw[!], etc)
    Whilst looking at pictures of them both they do appear to be identical.
    Anyone know for sure?
    Thanks!!!!
  2. Kobe Diesel
    Kobe Diesel New Member
    CT
    no, but a 929 shock is a direct fit
  3. rc24ste
    rc24ste New Member
    UK
    Thanks for the post.
    Why does the shock not fit? Too long? Mounting holes too big/small?
  4. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    The 929 is not a direct bolt on the clevis has to be machine.
  5. Kobe Diesel
    CT
  6. matt1986vf500f
    I stand corrected I though the lower clevis has to be machined
  7. hondabill
    hondabill New Member
    LANCASTER OHIO
    A 929/954 shock is not direct fit. Because it is shorter. Can be made to fit . But it does require a custom top clevis. A 6th Gen shock is approximately 3/8 in shorter as well. To maintain ride height it would also need a spacer on top.
  8. Kobe Diesel
    CT
    I think I've mistaken the direct fit shock option for the 5th gen maybe the F4i shock is direct, need to double check this
  9. NightViper19
    NightViper19 New Member
    Ohio
    Why is the 954 shock superior? I have an oil filled shock from a 95 954RR, but was using my VFR shock for the time being.
  10. Kobe Diesel
    CT
    It's fully adjustable 3-way
  11. NightViper19
    Ohio
    As in compression, rebound, and spring tension? I was thinking of having the oil filled shock revalved to get it just right to work with the extra weight. Any ideas on this?
    I am getting aluminum-bodied custom-built QA1 single adjustable shocks (controls both comp and rebound) with threaded spring seats for maximum adjustment for the front of the vehicle.
    I apologize if I am thread jacking.
  12. NightViper19
    Ohio
    Correction. I have the shock off of a 95 CBR900RR, It has comp, rebound, and spring seat adjustment, and it fits perfectly. The only thing is that it has a remote reservoir that might take some bracketing to hold. Not a big deal for me, since Im fabbing up my entire frame, but might make a difference for you bike guys.
  13. deanc
    deanc New Member
    near Atlanta, Georgia
    what about a 4th gen shock on a 3rd gen?
  14. Taximantom
    Taximantom New Member
    Hi. So could I go ahead and buy a vtec rear shocker and fit it on my 2000 fi has long
    Has I make up the 10 mm ?
    Regards
  15. VfR5ThGeNBlAcK860
    VfR5ThGeNBlAcK860 New Member
    Nightviper... Is the 95 900rr rear shock a direct replacement in a 5th gen vfr?
