Rebuilt Slave Cylinder NO CLUTCH NOW [emoji20]
Discussion in '5th Generation 1998-2001' started by nicholas042416, Jun 7, 2017.
  1. nicholas042416
    nicholas042416 New Member
    I rebuilt the slave on my 98 and now the clutch is useless! I have no idea which way the rubber seal is supposed to face that slips on to the puck....BUT I've tried it both ways and neither nets a result. What in the world could be the issue. It's properly bled, and has a good handle to it??
  2. ksoholm
    ksoholm New Member
    Shop manual.
  3. nicholas042416
    Got one on the way. All the online stuff is to hard to make out for me as far as diagrams go
  4. Expvet
    Expvet New Member
    Brooklyn, NY
    I rebuilt both slave and master on my 06 and had same no pressure issue. I finally used a syringe to push the fluid from the slave bleeder valve up to the master cylinder. Many micro bubbles later began to pump the clutch lever and pressure began to build up and successfully bled system, now working fine.
    nicholas042416 likes this.
  5. Darth Vader
    Darth Vader New Member
    melton mowbray
    I had a right nightmare bleeding my clutch m/c. The first time I did it was easy and straightforward but the last time it would not operate the clutch. There was no resistance eventhough fluid was there with no bubbles. In the end i reverse bled it with a big syringe and it worked but still didnt feel right. A ride round the block must have pushed a bubble somewhere and it worked . Dreading the next time.
  6. ridervfr
    Belgium
    I buy new slave cylinders I dont like overhauling them (lousy success rate.) I have done lots of calipers and master cylinders with good success with oem kits ad well as k&l.
    Sent from my SM-G900P using Tapatalk
  7. nicholas042416
    I finally got mine working....I would have bought a new one but I couldn't find a source anywhere that sold them new
  8. ridervfr
    Belgium
    Was looking for a clutch slave for your bike, surprisingly I could not find an actual part, they had the clutch and master cylinder set ups. Looks like the same rig that I use on my gen3 bikes though.
  9. nicholas042416
    Yep I couldn't either. All is well now, bike is up and running strong.
